Navigation - Post Code Search
Is it possible to use a postcode instead of an address to set a location on 2016 L&L Columbus Nav System?
yes, not as easy as it should be. When you go to the address entry page, there is a button for P.code?
This is curious because up until a few weeks ago I could type a postcode into the initial top search box on the Columbus and it would find the code and suggest and address automatically. This doesn't work any more.
So, to use a postcode....
1. Select "New dest"
2. On then screen that appears next tap on the "City" part
3. At the bottom left corner you should see a "Postcode"
4. Tap "Postcode" and enter the code
I have a MY2021 SEL iV with the Amundsen head unit.. Haven't done much navigating as of late, but i've noticed the few post codes i've entered, it displays a long/lat coordinate as opposed to the street name.. is this normal?
Thanks BOD20,
Successfully followed your advise.
Looks like a software update has in fact been a user downgrade.
May suit the programmer but not user friendly.
