Please help
Hello im new on this forum i need help i want change manual to electric wing mirror on my skoda fabiq mk1 i need connect now electric window wing on my motor of electric window
I believe the main wiring loom is probably the same for both types, you just need a pair of mirrors and the switchgear together with the loom extensions from the A pillar multiplugs which you'll need to pull through the rubber boot on each side. The mirrors do not connect to the electric window motors they are separate because they aren't electronic, they're purely electro-mechanical.
Thank you
Pretty sure they plug into the electric window motors.  See here at 1:57....
Hatboy Harvey is the bomb.
Yes, he makes great Fabia videos :thumbup:
Ok, I stand corrected, must be for the power feed I guess.
He deserves a video repository on here with an overview of all repairs so people have quick access to in-depth repair guides on common problems.
He most definately is - I have a lot of Hatboy jobs done on my car with no troubles - Between you lads and Hatboy its very easy to work on a Mk1 Fabia !!
