How to remove "Please have your vehicle inspected."?
Its a Superb 3V with VC.
Thanks!
Hi Freelancegamer,
You could try the procedure for removing the 'inspection service due' warning, which I successfully used on my 2016 Superb.
It is was in a thread in early October, where I was advised as follows:
"I've researched this topic extensively and several methods are suggested. As far as I can make out, for Superb iii with conventional dash, the method is something like.
Sit in car, doors closed, bonnet too. Press and hold SET button under dash clocks, turn on ignition (don't start engine), still holding down SET, wait until a "Reset Oil service?" message appears in the dash, continue holding SET and eventually a "Reset Inspection service?" message appears, immediately release the SET button and then press it again and release to do the reset. Not sure if it acknowledges, but then turn off the ignition.
Note that resetting this way will set the interval to fixed.
Never done it yet on my Superb so no guarantees."
It worked for me.
Paul R T
