Cambelt change
Hi eveyone
I just had the cambelt changed on my 2015 late skoda superb tdi sel.
About 100 miles in the glow plug light started flashing and acc not working and start/stop not working either. After inspection I found the dpf pressure sensors are... Well melted... There is soot in that area... Any help would be appreciated.
Thank you
There is a membrane inside the sensor between the inlet & outlet rubber pipe which measures the differential exhaust pressure.
It must have ruptured & allowed hot exhaust gas into the sensor & melted it.
You will need a new pressure sensor & adapted with VCDS.
Hi
Thank you for the information. Has this happened because the garage failed to recalibrate the sensor when the cambelt was changed?
