No DAB Signal on Bolero Radio
I never can get a DAB signal on my Bolero Radio in Octavia 2014 Mk3 does anyone have same issue and how was it fixed please?
Chris
First thing to check is that the DAB antenna lead is securely plugged into the main unit - which is the one in the glovebox (the screen in the centre console is just a screen).
Also check if you have any chargers or sat nav supplies plugged in anywhere as these can cause interference which will mess up the DAB signal
Can Dash Cam Hard Wired to fuse box cause any problems?
Yes, it can block the DAB signal completely
Not good system it was suggested by Skoda Dealer that the Aerial was behind the Dashboard and it was £18.95 for a aerial and £105 for fitting lol
The dab antenna is in the rear windscreen
Are you saying a new rear screen? Or is there a aerial amp in pillar somewhere that needs replacing?
I'm pretty sure James is suggesting the DC-DC adaptor in the hardwire kit could be causing interference, not that you need to start replacing things.
A good starting point would be to unplug it's fuse to see if that helps improve things.
It tends to be the GPS element of the dash cam that interferes with DAB. the use of certain dash cams or the routing of the cables can have a negative input on the DAB function.
As above - try using DAB with the dash cam disconnected. If the dash cam or it's wiring is the culprit then fit a ferrite filter block to the wiring near the camera to see if it helps.
There no GPS connected to my Dash cams
What brand are they?
Do you have a front and rear?
I've seen the switch mode power supplies for dash cams radiate interference on many frequencies. It shouldn't make much of a difference if it has GPS or not.
Some of the kit we build at work kills our office DAB radio dead until I put it in a shielded container. Even then, it can radiate from the power cables if we're not careful.
It might be a bit of a stab in the dark for you but certainly the first place I'd look. Even if the dash cam isn't turned on, the power supply will still potentially interfere with your DAB if hard wired.
Thank you for everyone help I tried all your ideas not one worked still no Signal taken Cd Unit main Source all connected. Taken centre screen out all connected.
I am baffled were else to look.
Can I connect a aftermarket DAB aerial to these units?
Yes you can attach an aftermarket antenna. You'll get a fault code but DAB will work.
