My 2008 model Skoda Laura losses power and didn't cross 2500 rpm
I have Skoda Laura 2008 model which loses power when we are in traffic or slow moving.
If we start the car at first time the rpm will not cross above 2.5 if we tried to cross the rpm shuddering sound from engine can hear.
When we stop the engine and restart it immediately and accelerate  the engine pick ups and car cross the rpm and power will be there. But after driving some time in heavy traffic or we slow down the car losses power and it will not cross 2.5 rpm again.
Tried cleaning maf no response, fuel filters and air filters changed no response.after cleaning egr got little bit more power to drive for another 2000 kms. After some time it loses power again and need to re-start to get power for some time.
Without power we can hardly touch 100 km in highway.
And I noticed heavy fuel consumption and blacksmoke too.
And the mechanic told to change ecm and check again.
Car has done 1lakh kms
And engine light was on. But showing maf sensor but tried replace with another one but same issue.
Another issue some time abs and asr light will show.but go immediately after some time.
Can any one help us to find the  real problem.
Tried several injector cleaning solution too.
Think you have several issues going on, best to get Error Code scanner/VCDS to scan them.
Is it a petrol or diesel?
As for not reving  past 2500RPM if its a diesel then could be the EGR or Crankshaft sensor.
ABS light could requiring new wheel hubs are the sensor is within the hub.
However you wont be 100% sure until you scan for Error codes.
