Montaż kamery cofania do radja bolero 2014 rok
Potrzebuję pomocy chciałbym zamontować kamerkę cofamia mam fabie 3 2014. Prubowalem sam i nie idzie
Dodam że posiadam radio bolero
This is British forum so you shoul duse English, no Polish (even if both of us are Poles :) )
Model number (e.e. 5Q0035819) and Software version (e.g. 0137) of your Bolero?
Ok sory
58 minutes ago, pab567 said:
To jest forum brytyjskie, więc powinieneś używać angielskiego, żadnego polskiego (nawet jeśli oboje jesteśmy Polakami :))
Numer modelu (ee 5Q0035819) i wersja oprogramowania (np. 0137) Twojego Bolero?
Unfortunately 5Q0035819 does not support rear view cameras - it doesn't have video chip. You either have to use special external adapter or replace infotainment unit with Bolero 5Q0035840x (non-DAB) or Bolero 5Q0035842x (DAB) or Amundsen 5Q0035864x (non-DAB) or 5Q0035874x (DAB). x means letter (A/B/C). There are also Bolerow without letter at the end but I do not recommend them as they don't support SmartLink but only MirrorLink.
Thank you
Pab567
Can I add rear camera in my new unit
6V0035869H
6V0035869H
I have the model 5Q0035840B, so the video chip is present. When I search on google for rear cameras I find find a lot of cheap and alternative solutions that doesn't utilize the Bolero system. So can you point me in direction of rear cameras that actually works with the bolero system? Or should I just visit my local Skoda dealership?
On 07/12/2020 at 11:18, RABAH said:
Pab567
6V0035869H
6V0035869H
No clue, I don;t work with these units.
@nosalismus any CVBS NTSC camera will work, including the cheap ones (15-20 GBP) from aliexpress
