Fuel filter replace broken clip
Just about to replace the fuel filter, but I noticed one of the clips has sheered at some point (photo attached). Does anyone know the where I can find a replacement?
Thanks!
Don't think I've seen them in DIY type places. You could replace it with a jubilee clip (careful not to over-tighten!).
If you want to replace it with one of the same type then you could try looking for similar cars being broken for spares on eBay/Facebook etc or the wanted section. Failing that I expect dealers will still be able to get them.
The VAG part number is N10292201, which is common across most of the group's vehicles.
There are some listed here on fleabay or here on skoda-parts.com and I've included a Brisky thread below which discusses the general issue:
Brilliant - have ordered one. Thanks a lot!
For anyone else reading this, turns out the Haynes manual actually recommends replacing the original clips with worm drive clips 'of the correct size'.
So I guess either works
