Hood connector polarity for Superb mk2
Hi All,
I am having Skoda Superb mk 2 and I want to want to reconnect the bonnet lock sensor cable which was chewed by rats earlier. I need help in identifying the connector polarity (which is positive and negative). Its a 2 pin connector as shown in attachments.
Thanks in advance.
Edited by kunalvaidya
  • kunalvaidya changed the title to Hood connector polarity for Superb mk2
It doesn't matter. The microswitch is just going to connect/disconnect the two wires.
I need to solder 2 wires which are cut, which are behind the connector. Currently the connector does not have any wires either.
Whichever polarity you choose it will work the same.
seconded
Thanks for your replies, I figured it out finally .... There is numbering at the back of connector.
1 is positive
2 is negative
soldered the wires all good :)
