abs coding
Welcome to the halfords workshop, they replaced the battery for me. After replacement, manual traction control abs flashes all the time.
after connecting the computer, no abs coding.
how to generate such a code or let someone help
vin : TMBBE73T5A9019178
Part No SW: 3T0 907 379 C    HW: 3T0 907 379 C
Component: ESP MK60EC1   H45 0104
engine 2.0 tdi 103kw code engine BMP
right-hand drive
only has an on / off traction switch
right-hand drive
frond disc  312
rear disk 282
You're saying the coding in the ABS module has been set to all zeroes?
You should be able to use the long coding helper to walk you through setting it up again.
so was lost
Variant coding : 00_00_00_00_00_00_00_00_00_00_00_00_00_00_00_00_00_00
and you can't generate such code
VCDS has a function called Long Coding Helper which shows you what the options are for each byte in the long coding. You can use that to tick the boxes that apply to your car and it will generate the long coding.
At the moment I do not have vcds, I ordered that I will have fun.
I thought there was someone able to generate it
So what scan tool have you been using until now? Some cheap tools have been known to mess up coding on control modules.
 wow
If the coding was lost during the battery replacement by Halfords, I'd demand Halfords fix it.
Even if that is just Halfords paying Skoda to recode it...
