octavia 54 plate 2L auto Estate air bag warning light
Air Bag warning light has come on, engine management light NOT on, cheap ODB scanner says no errors. Checked plugs under front seats seem ok any help please.
Welcome!
Sounds like you need a better OBD scanner :)
If the airbag light is on, there will be a fault code stored explaining why.
engine management light is NOT on??
I didn't say it was?
You said the airbag light was on, I said there will be a fault code explaining why...
If your current obd tool doesn't show any faults relating to airbags, it sounds like you need a better obd tool.
OK i will find a better one but i thought if the engine management light was not on there were no faults. thanks
The key words being "engine management".
Airbags have no bearing on the engine.
Hi MicMac i thought so but then were are people getting these error codes and diagnostics from?
The MK2 Octavia is a CAN-bus based car with numerous electronic modules.
This is a scan from a 2006 model to give you an idea:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 LB
   Component: R4 1,9L EDC G000SG  8501
   Revision: --H02---    Serial number: SKZ7Z0F3652414
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6ADC5BAB45D8541F19-803E
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8ADAFF6EDA01B79E-806A
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B72AEEF7AC21D97B2-806E
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004124048
   Coding: E18A0F231004140046110D000000000000087F075C
   Shop #: WSC 66001 476 10392
   VCID: 2B529EAF8AA28D1722-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 66001
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00471077
   Shop #: WSC 66001
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475     HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0004
   Revision: --------    Serial number: 66640904803454
   Coding: 000002
   Shop #: WSC 73430 790 00999
   VCID: 7EF467FBE950C8BFD5-802A
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: Q4 AIRBAG VW8   018 2300
   Revision: 04018000    Serial number: 0038MD0G5EUP
   Coding: 0020788
   Subsystem 1 - Serial number: 6332MSME0F20057DD
   Subsystem 2 - Serial number: 6342MSME0E7E4673R
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0003042
   VCID: 77FA72DF066AF9F796-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610036    Serial number: SKZ7Z0F3652414
   Coding: 0007401
   Shop #: WSC 28027 067 57207
   VCID: 397EB4E770FE2F87A0-806C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 300410F2000053
   Coding: E9A07F06400612002303
   Shop #: WSC 01324 020 00200
   VCID: 69DE24A740DE5F0710-803C
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 246370 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:15:24
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665406599
   Coding: 020100
   Shop #: WSC 00788 648 00255
   VCID: 2B529EAF4AA28D1722-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 E    HW: 3T0 035 680 E
   Component: RNS-MID       H61 3984
   Revision: AB001001    Serial number: SKZ6Z7M9023136
   Coding: 06000402040100010011
   Shop #: WSC 33361 790 00999
   VCID: 326C83CB6D88DCDF61-8066
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000758
   VCID: 3664BFDB41E0C0FF4D-8062
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 346085D3579CD2EF73-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 08D002407B008505C85F861004CC
   Shop #: WSC 73430 790 12345
   VCID: 79FE74E7307EEF87E0-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000758
   VCID: 377AB2DF46EA39F756-8062
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 326C83CBAD88DCDF61-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 336286CF5292D5D76A-8066
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661251715
   Coding: 0210000001010110
   Shop #: WSC 00028 028 00023
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 26446F9B5940B07FFD-8072
End-------------------------(Elapsed Time: 02:25)--------------------------
As you can see, there are separate modules for the engine (ECU), airbags and many other things.
It's entirely possible for a fault to show in the airbag system causing the warning light without an EML showing.
You might even find that it's a previous issue so all you need is the code clearing as airbag faults typically won't self-reset.
Edited by langers2k
I had this problem on a 2007. I have posted on this subject on this forum as have others, check them out. You cannot check the plugs, they are spring loaded and cause an intermittent fault. I will bet you will find the problem is the driver's seat, yellow 3 wire connector underneath the seat roughly in the middle.
You may find you can cancel light and it never comes back. It is an MOT failure. If it does keep coming back I cut the plug and socket out and soldered the wires. You should take precautions to avoid airbag deployment if you decide to go the DIY route.
