Multimedia upgrade from Swing to MIB2 with NAV..
A4NOY
Recommended Posts
I purchased a second hand MIB2 unit from Maciej Początek on face book ready coded plug and play..
1.remove old head unit and glovebox Photo 2 & 6
2. cut away apart of the old head unit carrier as photo 7
3. move blue and green connectors from old quad lock into new wiring adaption loom photo 9
4. remove the 2 can wires from old grey connector and fit into new connector in the new quad lock ... see photo 8 & 1
5. slide wiring through into the glovebox area and connect to MIB2 unit... see photo 10
6. fit GPS aerial under dash ( onto of the heater)
7. slide MIB2 unit into the slot made into the old head unit carrier from the glovebox side
8. refit glovebox.
9. remove the upper 2 locks from the new head unit. you can be brutal and use a set of pliers.
10. slide new head unit into place photo 11
11. go through settings to make personal adjustments
12. code instrument cluster for nav with vag-com or similar
parts used :
MIB2 unit second hand : 5Q0 035 874 C
conversion loom. https://www.aliexpress.com/item/4000232403998.html?spm=a2g0s.8937460.0.0.fdd82e0eCVlIZM
head unit second hand : 6V0 919 604 B
GPS aerial : Ebay
  • Like 2
  • Love it! 1
Link to comment
Share on other sites
  • 2 years later...
Hi A4NOY,
If I understand correctly you placed the MIB2 unit in the carrier where the original unit was located (behind the screen)?
You've cut away some of the dashboard so the unit could be slid in from the glovebox, couldn't it be slid in from the front?
Is the unit still fixed or is it loosely placed in the available space there?
Are you able to access the unit from the glovebox, or is it fully hidden inside the dashboard now?
Looking to do a similar upgrade (swing to bolero head unit) but since I do not seem to have a dedicated location for the MIB unit in the glovebox I was wondering how this unit could be build in.
Sorry for the spam questions 😅
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
