Water in footwell
Robbsey
Hi                                               Having a problem with pool of water in front footwell, sunroof drains ok, no water from bulkhead seems to come in from where door seal sits  on sill but seal is intact.
Any other ideas before I buy a new door seal
  • Administrators
Very common issue. Check the door seal and inside/behind the door cards to make sure the plastic door coverings are in tact. Double check under the scuttle panel (both sides) as there are two small bungs which you can see straight into the footwells. Drivers side should be the bonnet release cable and the passenger side will just have a bung if it's there.
