Coding for 6C highline Rear View camera
Hi,
Does anyone have the coding for the 6C rear view camera?  I fitted the camera to my manual MY16 Octavia Mk3 Scout and it works mostly.  Coding for the MIB2 etc was fine, but I'm not completely clear what the coding should be for the camera itself.  Teh image displays and the guidelines move with the wheel.  However occasional the camera does not display on selecting reverse, I think it may be related to the parking sensors being triggered before selecting reverse.  I see there is a entry in the coding to tell it which gearbox is fitted, so I wonder if it is related to this?
Thanks,
Jon.
That byte will be 02 for manual and A2 for DSG. Coding alterations will largely depend on dataset so you can’t alter too much within the coding.
My friend had the same problem after fitting the camera. Solution was to change the MIB unit. Sometimes it is not working (faulty hardware). Tried to do calibration and parametrization too, but without any help.
Just saying that, because it could be your problem too.
Thanks Sasha, I think I did that but wasn't sure about the other bytes.  The VCDS label file doesn't make a lot of sense to me as it's all abstraction layers.
As an aside, I'm very impressed with the quality of the OE camera and processing.  It's surprisingly useful, especially with my sticky outy towbar.
Cheers,
Jon.
