Yeti Window Master Switch removal
Hello,
Does anybody know the easy way to remove the drivers door master window switch from a 2016 Yeti Outdoor? YouTube seems to concentrate on Octavias and Golfs etc. which are different.
The choice appears to be between removing the entire door panel or possibly prising out the switch surround. I would prefer the latter, but would welcome any advice
Many thanks, exactly what was needed. Will attempt the job this weekend.
  • 2 years later...
Hi
Hoping to do the same with my 2016 Skoda Yeti (not Outdoor) , If any one has any more images on the above, appreciated, I have to do the same, just a little usnure why the first step is needed
lifting off the cover for the hande.
Thanks Colm
It's probably showing how to remove all 3 trim pieces.
Those photos are for removing door cards to access all the torx screws & connectors to undo wiring.
To replace the window switch you just need to insert the screwdriver where shown and push forward & up.
