1.4 16v intermittent starting problem
Hi all, my 1.4 16v fabia sometimes takes a good 15 to 20 seconds of turning over before it fires, then it seems to run on 2 or 3 cylinders for a few seconds then runs on 4. It puts out a bit of white smoke and stinks of petrol when it does get going on all 4.
It sometimes happens daily and sometimes not for a week or longer. I put new oil and spark plugs in about 4 month ago and have done less than a 1000 miles on them.
Does anyone have any idea where i should start fault finding? Cheers all
Coil pack or ignition leads depending on which engine you have.
I believe it is a bbz engine mate
Then you have at least one failing coil pack.
Does this sound qbout right then mate, are they intermitent when they start too fail? I have a couple of spare ones i got from my local scrap yard that look quite new, worth swapping for them do you think?
A cheap handheld scantool or VCDS Lite may well help you to identify what is wrong.
Yes, swap out 3 & 4 to start with and see if it improves, if it stays the same then swap 1 & 2 with the ones you took out.
I have a scantool it doesnt show any faults mate
Cool man ill do it this weekend, thanks for the advice 👍
Have you got a multimeter to check battery voltage before and after starting?
At the back of my crammed in container 😂 i could borrow one from someone at work though
Sounds very familiar. :D
Thats it now the car wont start at all haha plenty of fuel getting through so not getting a spark
