Lowering Scout suspension
Hi
anyone have any experience lowering or upgrading the suspension on a scout?
2015 model
Edited by john999boy
Title change
  • john999boy changed the title to Lowering Scout suspension
Well - I would definitely suggest NOT lowering the Scout's suspension.  If you are going to do that, you would be sensible to go back to standard suspension.
Might I suggest retrofitting suspension from a FL Scout onto your 2015 car?  I had a 2016 Scout - and I agree that the suspension was *rubbish*.  My 2019 Scout suspension is AMAZING - wonderfully wafty suspension that makes driving the car so much better.
I'm with V on this. But if your going too, i would upgrade to better parts. 👀
You could probably use OEM parts from a 4x4 vRS? Or aftermarket parts for the same?
It might be easier and cheaper to p/ex the Scout for a 4x4 vRS though...
Or have you 'sleeper' plans for it, dropping an RS3 engine in it maybe? :cool:
@varaderoguyWhy do you consider the 2016 Scout suspension to be rubbish?
Edited by Deerfoot
Missing reference
I have a 2016 Scout, and have found it very good, even when towing.
Its horrible and crashy.  Not at all relaxing.  Compared to my 2019 Scout, it is chalk and cheese.  I found it overly stiff and jarring, especially at main road speeds.  The suspension in my MY2010 Scout was better than the MY16 car.  Asked dealer about it when I first got the car; he basically stated that they were all like that.
Edited by varaderoguy
I suspect that when you put loads into the boot or were 4 up, the car probably would react better.  I tended to be driving alone most of the time on my errands; kept the tyres at about 34/35 PSI (because 32PSI was too low).
Skoda Octavia MK3 Estate 150HP 4x4
5Q0411105GL (manual transmission)
Fitting Position Front Axle
Colour Coding Blue, Brown
Wire Diameter 12,00 mm
Length 314 mm
Outer diameter 149 mm
Weight 1,60 kg
(1) 5Q0411105GL coil spring
1 paint mark
1 paint mark
blue
brown
Model data: PR-L06
https://web.tecalliance.net/gkn/en/parts/1/87621/detail?targetType=cars&targetId=59490&typeNumber=59490&groups=188#@brc/brands:Car;targetType:cars;mandator:gkn/assem:SKODA%20OCTAVIA%20IV%20Combi%20(5E5%2C%205E6)%202.0%20TDI%204x4;targetType:cars;mandator:gkn;targetId:59490;typeNumber:59490/lnkparts:Coil%20Springs;targetType:cars;mandator:gkn;assemblyGroupId:100113;targetId:59490;typeNumber:59490;groups:188;brands:1;page:0/detail:87621;brandId:1;articleNo:87621;mandator:gkn;targetType:cars;targetId:59490;typeNumber:59490;groups:188
https://www.autodoc.co.uk/car-parts/oem/5q0411105gl?search=OEN+5Q0411105GL&supplier[0]=32
5Q0411105GM (automatic transmission)
Colour Coding Blue, Grey
Wire Diameter 12,25 mm
Length 315 mm
Outer diameter 146 mm
Weight 1,70 kg
(1) 5Q0411105GM coil spring
1 paint mark
1 paint mark
blue
grey
Model data: PR-L07
https://web.tecalliance.net/gkn/en/parts/1/87622/detail?targetType=cars&targetId=59490&typeNumber=59490&groups=188#@brc/brands:Car;targetType:cars;mandator:gkn/assem:SKODA%20OCTAVIA%20IV%20Combi%20(5E5%2C%205E6)%202.0%20TDI%204x4;targetType:cars;mandator:gkn;targetId:59490;typeNumber:59490/lnkparts:Coil%20Springs;targetType:cars;mandator:gkn;assemblyGroupId:100113;targetId:59490;typeNumber:59490;groups:188;brands:1;page:0/detail:87622;brandId:1;articleNo:87622;mandator:gkn;targetType:cars;targetId:59490;typeNumber:59490;groups:188
https://www.autodoc.co.uk/car-parts/oem/5q0411105gm?search=OEN+5Q0411105GM&supplier[0]=32
5Q0511115G (without towbar)
Fitting Position Rear Axle
Wire Diameter 11,75 mm
Length 367 mm
Outer diameter 113 mm
Weight 1,95 kg
(1) 5Q0511115G coil spring
Model data: PR-1JA+0YH
https://web.tecalliance.net/gkn/en/parts/1/87967/detail?query=5Q0511115G&numberType=1&oe=5Q0511115G#@brc/search:Search%20by%20any%20number%205Q0511115G;mandator:gkn;query:5Q0511115G/detail:87967;brandId:1;articleNo:87967;mandator:gkn;query:5Q0511115G;numberType:1;oe:5Q0511115G
https://www.autodoc.co.uk/car-parts/oem/5q0511115g?supplier[0]=32
5Q0511115H (with towbar)
Length 367 mm
Outer diameter 110 mm
Weight 2,20 kg
(1) 5Q0511115H coil spring
Model data: PR-1JA+0YJ
https://web.tecalliance.net/gkn/en/parts/1/87968/detail?query=5Q0511115H&numberType=1&oe=5Q0511115H#@brc/search:Search%20by%20any%20number%205Q0511115H;mandator:gkn;query:5Q0511115H/detail:87968;brandId:1;articleNo:87968;mandator:gkn;query:5Q0511115H;numberType:1;oe:5Q0511115H
https://www.autodoc.co.uk/car-parts/oem/5q0511115h?supplier[0]=32
Edited by Carlston
No, just me or me and the wife, most of the time.
