Water pump replacement Skoda Fabia Mk2 1.2 TSI
Hi there,
I have a coolant leak on a 2010 1.2 TSI petrol Fabia which I assume is due to a broken gasket on the coolant pump.  As yet I haven't had any success in replacing the coolant pump as there is very little space in which to work.  Does anyone have any advice on how to do this or is able to point in the direction of a thread that has already covered this?
Cheers very much.
I have no direct experience of that particular engine but most modern cars have the same access issues, you simply have to dismantle and remove other equipment in order to gain access or work from underneath the car.
Many thanks, will look in to that.
