VCDS Coding Issue (High Beam Assist/Virtual Subwoofer)
Hi All,
I have a 66' Octavia VRS and I am struggling to get HBA to the Virtual subwoofer ones to work!
HBA
I don't seem to have '(2) Assistant Light Functions' appear on VCDS.
Virtual Subwoofer
I don't seem to have the option to change from 0 to 1 as per the instruction below.
2 - Select Long Coding (Select 1 from top menu not 0)
I have attached some photos of what options I have on screen, I am probably missing something very obvious.
Any help would be appreciated.
When scrolling through Adaptations in VCDS it doesn’t have sub menus, so you’ll need the next set of instructions for the menus you are after, all of which are there, anything related to Fernlichtassistant which is HBA in German.
For Skoda Surround you need to enable text mode or experimental coding or you can change that coding string via copy paste but change Byte 11 from 01 to 04.
If you create an "Admap" for that controller and open it in excel. You can copy the "words" out of each adaption channel line and paste it into Google translate, German to English. It does a very good job of translating them to be honest.  Easier than going back to school and  learning German..
