Electrical relay problems (Help & Advice Please)
There is no fault other than the alarm horn. I would guess that is after he cleared the original scan,
A lack of power supply to a module will leave faults in that or other modules
yes the codes were cleared will they not show up on another scan if i go try and start it?
go and try starting it, then do a scan
ok will do that now
Tuesday,30,March,2021,15:51:57:35642
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBKE21Z   License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
VIN: TMBKE21Z   Mileage: 311810km-193749miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 SS    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1302
   Revision: --H07---    Serial number: SKZ7Z0G4311023
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 025C73D48807A2BB997-8056
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00H14001
   Coding: 0023170
   Shop #: WSC 73430 790 00000
   VCID: 698E4478957151E338D-803C
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 45D6A8C8D9A95583FC5-8010
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005018991
   Coding: E18A0F130004100000110D000000000000087F065C000000000000000000
   Shop #: WSC 07894 067 57207
   VCID: 71BE2C18BDA1A92370D-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060607 022  0601
   Coding: 00055223
   Shop #: WSC 07894
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     250607 046  0204
   Coding: 00471077
   Shop #: WSC 07894
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1A3RTX
   Coding: 0020788
   VCID: 3D26C028B1791D43A45-8068
   Subsystem 1 - Serial number: 6332MSME184A620EG
   Subsystem 2 - Serial number: 6342MSME1C044D46G
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002042
   VCID: 015E7CD88D01B9A380D-8054
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4311023
   Coding: 0007402
   Shop #: WSC 11111 067 57207
   VCID: 392ED438A551216388D-806C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 160607F2000472
   Coding: E9837F0E0002022303
   VCID: 3038E91C762BE02B3F3-8064
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3634DF04944FCE1B65F-8062
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000758
   VCID: 3828D13C9E5B386B773-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3430E50C8233DC0B5BB-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F02050FC0085F96907C00
   VCID: 035276D0971DABB3921-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Component:   Sounder No Answer
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:26:06
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000008
   VCID: 74B0250CC2B39C0B9BB-8020
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0019189
   Coding: 0000402
   VCID: 2E04F7646C1FF6DB2DF-807A
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 372AD200934537137E9-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
think there's 2 faults now but cant find what they mean have you have a chance to look them up?
what faults have you got now?
it says number 46 twice:   46-Central Conv. -- Status: Malfunction 0010
not sure what that means as lots of conflicting things coming up on a google search
Tuesday,30,March,2021,15:49:02:35642
www.Ross-Tech.com
VIN: TMBKE21Z788009343   License Plate:
VIN: TMBKE21Z788009343   Mileage: 311810km-193749miles
   Coding: 0000172
   Revision: 00H14001
   Coding: 0023170
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
   Coding: 0020788
   Coding: 0002042
   Coding: 0007402
   Coding: 0000001
   Coding: 0000758
   Coding: 00000000
   Shop #: WSC 73430
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:26:06
   Coding: 0000758
   Coding: 0000008
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
What happens when you lock the car with the remote, wait a minute then unlock with the key in the door?
Just went out and tried that MicMac and nothing happens, only get the warning lights now when I turn the engine over and it beeps (not the horn)
do you know how that relay box comes out I found 2 torx screws but cant see  anything else holding it in place
Edited by sealover1
Ok just a quick update I went out with my trusty caravan battery fully charged and hooked that up with thick jump leads and no start though did turn over a lot better, tested the battery it come up good battery needs charging,  then I found out how to get that module out and got my contact cleaner and took out every fuse every relay I could see even ones under the bonnet and driver side fuses, got behind the Module and gave it a dam good spray and wiggled all the wires and plugs, then sprays every single fuse and relay and pulled them in and out a couple of times.
Connected the battery up and it started 1st turn
got it connected to the smart battery charger now and will leave it to charge for 24 hours and then hopefully put all the dash back together. you dont undo the torx screws to get the module out there are 2 clips on the sides and it drops down with a wiggle and a pull, thought i,d put this in case anyone else dont know how they come out like me.
I did have the steering wheel warning light lit up and the traction control light but sometimes they go out after a drive so I seen before, its a new steering rack so wont be that at least and all the brakes i have been done 2 years ago,
will update you all tomorrow or after the car is put back together.
thank you all for your help I'm disabled and on low income so its a huge help when you guys step in and help us save garage fees.. Alan
Edited by sealover1
Hi Guys after charging the battery as advised its now showing a good voltage after 2 days of leaving it on charge,
put all the dash back together this morning and went for a drive and the abs lights and steering lights have gone out but now it started beeping engine fault take to a garage.
this is a new scan I done a few mins ago any ideals what it could be? I dont think its the horn? the car still starts up though
or should I start a new scan thread??
Friday,02,April,2021,12:43:42:35642
www.Ross-Tech.com
01-Engine -- Status: Malfunction 0010
   Coding: 0000172
8 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:06:19
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.64 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 00110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:06:19
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.64 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:06:19
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.64 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:06:19
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 10.64 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 00110000
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 000 - Malfunction - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 777 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.55 V
                    Bin. Bits: 00101100
                    Absolute Pres.: 1224.0 mbar
                    Absolute Pres.: 999.6 mbar
005269 - Switch-Over Valve for EGR Cooler (N345)
               P1495 - 000 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 255
                    Mileage: 311813 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:21:19
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.69 V
                    Bin. Bits: 00101100
                    Mass Air / Rev.: 795.0 mg/str
                    Mass Air / Rev.: 470.0 mg/str
000581 - Solenoid Valve  for Boost Pressure Control (N75)
               P0245 - 000 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 311813 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:21:19
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.92 V
                    Bin. Bits: 00101100
                    Absolute Pres.: 1122.0 mbar
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - MIL ON
             Freeze Frame:
                    Fault Status: 11110000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311813 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:07:35
             Freeze Frame:
                    RPM: 924 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 100.6 %
                    Bin. Bits: 00101100
                    Mass Air / Rev.: 635.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
Readiness: 1 4 0 0 0
   Revision: 00H14001
   Coding: 0023170
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
   Coding: 0020788
   Coding: 0002042
   Coding: 0007402
   Coding: 0000001
   Coding: 0000758
   Coding: 00000000
   Shop #: WSC 73430
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 8
                    Reset counter: 167
                    Mileage: 311812 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:26:06
   Coding: 0000758
   Coding: 0000008
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
End----------(Elapsed Time: 01:20, VBatt start/end: 12.9V/12.8V)-----------
(update )Sorry guys it does help when you push all 10 the engine management fuses and relays back in correctly
