VW polo 9n BKY engine
Hello team my vw polo coolant tank is boiling but the temperature is normal any help?
Is it boiling or is it bubbling because it’s pressurising?
Boiling like water in a kettle
Do you have pressure in the hoses or cold spots in the lower coolant hose. Have you checked your oil for contamination from a head gasket issue. The other item I’d look at would be water pump.
do you have heat from the heaters?
Edited by UndertheRadar
I haven't check the lower pipes the oil is ok i check yes for heaters are working the is pressure in pipes but i end up removing a thermostat but it's still the same 🙆‍♂️
