Memory seats
1 hour ago, nidza said:
Most of posters here described exactly as it is in O3, as O4 is more-less exactly the same car mechanically. I will try to put into one message all information, so OP isn't confused:
1) Different keys, different seat and mirror position, but it must be set in head unit (it's off by default)
2) While in car you need to hold the button, as a safety measure, because it allows seat memory recall during driving - please imagine your seat goes all the way front or back, while on a highway, if you press 3 instead of 1 for example, or kids played before. You could easily crash.
3) When you unlock the car and open the door, pressing the button shortly will do the memory recall position all the way, without holding. So, two drivers, one key, each one calls back memory position which he put. This use-case isn't a safety issue, because the car is standing still.
That’s helpful. Thank you
bravo brate , u helped a lot. cheers
