Fit new grille without removing bumper
Hi
I just ordered new grille black glossy with black glossy surrounding so complete grill. Do i need to remove whole bumper ro take off whole grille or can
i do some other way?
How is whole grille fitted on the bumper? Screws? Clips?
My car is Octavia MK3 Facelift 2019
Bumper off job ,believe the grill is plastic welded in place
Welded? Så i need to weld new one?
It clips.
You will probably break the old surround removing it, it can be done without removing the bumper, at that stage you can decide how much forcing will be involved to fit the new one, if its too much then remove the bumper.
9 minutes ago, J.R. said:
It clips.
I will remove whole bumper and i did not order just surrounding i ordered whole new grille with surrounding on it. Its glossy black
The surround clips on the grill doesnt ,i think ,plenty of info on the site about replacement grills
There is alot of info but no photo of grille is welded or clipped in place . Removing bumper is not the problem for me, i just wondered if whole grill was welded in place on the bumper or not. I know that surrounding is clipped but not sure for the whole grill. But i found a vid on YT after my post so i got my answer. ITs not welded
Edited by bihslk82
Everyone on here whos replaced upper grill have stated that its plastic welds not clips so fingers crossed for you ,let us know how you get on 👍
I know that but if you look at the video i linked it shows clearly no welding.
But i will take photos and post it here when done with replacement
I have just done exactly the same on my 2020 octavia FL, If yours is a FL the grille is not welded in place but is held in by lugs on the bumper, however the bumper does require removal which is quite easy on these 👍
Edited by Tebba61
Hi mate. Mine is FL yes 2019
The whole front bumper needs to come off - its a pain, but not impossible with a second pair of hands and some patience.
Yes know that now it will be ok. I will post a PIC when its done.
bookmarked!
Grille mounted today. Took 1 hour and easy as FCK :) And the question about if its welded or not so NO its not on FACELIFT
178558574_10159254834637276_3495145119181548511_n.thumb.jpg.6a568c92446d5cf8fe2badde57620441.jpg
Edited by bihslk82
Nicely done!
1 hour ago, BeVe said:
Nicely done!
Thank you!
