1.4 BBZ engine stopped and won’t restart
Hi,
Driving home the engine died on me, from about 30mph and 2500 rpm it gradually died, no juddering, no ominous sounds.
I got it pushed back home. Now it won’t restart.
Have looked at the following
- VCDS, no codes thrown
- Fuel gauge says 3/4 full but added some anyway.
- EGR valve removed and sprayed with cleaner and refitted.
- Fuel rail valve spits a tiny amount of fuel out when you press it.
- Spark plugs look to be getting fuel to them
- We disconnected one fuel injector and got a code, as expected
- Don’t think it’s a coil pack as I had one of those go before and the car ran rough and would start albeit roughly. Now it won’t start at all.
- Pulled one spark plug out, reconnected coil pack, and earthed it, tried starting. No spark seen.
Ideas welcome.
and
Replaced that coil pack, didn’t make a difference.
Check the timing belts are intact.
Thanks. They seem to be, from opening the upper cover (second video link).
Wow, I didn't even watch the video, I'm not really a 'visual' person because I can use words.
I wonder if the throttle body has packed up.
Throttle valve looks like it opens and closes ok. (Also did a VCDS test of that before doing a test of the EGR valve while it was out.)
Also tried a different ECU.
Edited by jonmad
Immobiliser LED on the door going off when you try and start it?
  • Sponsor
Checked any fuses? 52 feeds the ignition coils.
Ah. We checked 17 and 56.
52 was kaput. I swapped it with 50 (RH dipped beam). It blew when I turned the ignition on (I heard it go click).
  • Sponsor
Short to ground somewhere between fuse and last coil then, I guess? Or one of the coils shorting internally.  Disco all but one, try another fuse, then keep adding them in one at a time if that one doesn't re-blow the fuse?
Thanks Wino, that’s a great help. I’ll order some fuses then see how I get on.
Perfect! One of the coils blew the fuse. Replaced it with a spare and all good. Thanks so much for suggesting that fuse. We’d checked a couple of others based on another post somewhere, but didn’t go down the list looking for other likely fuses to check.
  • Sponsor
Great news.  To be honest, your description of the fault and what you'd tried already went a long way to pinpointing the likely problem area. :)
