Felicia 1.3 mpi oil leak
Hi, I've just bought a Felicia pacific estate 1 3 mpi, which is a lovely low mileage car.
One of the few problems I have is an oil leak from the cam follower cover on the side of the engine. I'm after the parts numbers for the gasket and the rubber washers that hold the plate in place if anyone can oblige.
Thanks in advance.
There is a pinned topic in this section of the forum called Online catalog with PART NUMBERS and ILLUSTRATIONS
Before presuming I needed a new cover gasket I'd check the torque on the cover bolts is right. I've fixed several similar sounding leaks that way for no money and next to no time.
Edited by KenONeill
047103483 valve cover gasket
047103532 rubber round things below nuts
