1.4 tsi whistle noise when revving
hello,
does anyone has the same issue or a clue what is causing it?
The engine is 1.4 tsi 2016 and the mileage is about 40k km.
https://youtu.be/meQRnaX83iQ
anyone?
Check all pipes from the airbox to the turbo and turbo to the inlet manifold, even a small split can cause a very audible whistling.
What is your performance like at the moment? That sounds like the beginning of turbo bearing failing (the squeak sounds like the opening of the blow-off valve). When did you last have an oil change and filter and what oil are you using?
As Pagan has suggested, it is also a good time to check for air leaks. A failure of the seal around the airbox will also make the noise (although it would be more of a woosh noise). Check to see if your air filter is also blocked.
all pipes are checked, skoda dealer said it's normal but I don't believe it
The performance is fine. I'm changing the oil at 10-12 000 intervals. I'm using Castrol LongLife III 5w-30. After recent oil change, there was no difference in the sound.
When the engine is very hot, I can barely hear it.
Maybe it's worth saying that I don't have any oil consumption within 10 000 kilometers
