Dynamic road sign display currently restricted
Hi all
I have kodiaq i see this message
How to sloved it
I Have nav but maps not for my country
i cant find maps for my country
palestine
did the problem is from maps
or other things
thanks all
12 minutes ago, leo297 said:
I cant find maps for my country
palestine
Well, Palestine is not a country... but a region of the Middle East.
Yes, it`s maps. Although the camera makes most of he time road sign readings, the base for sign recognition lies in maps. I get the same warning on new road sections, which are not on the map yet.
Same for me in AU, maps not homologated for this feature here so when I enabled TSR on my car I get this warning 2 mins after starting the car.
In practice it does not affect the operation, other than:
- The message is logged in the module
- Signs are not necessarily recognised in their true intent (e.g. we have some 'school zones' that operate part time but the TSR just reads the sign but not the time periods and assumes the lower limit is always in operation)
Yep same here in NZ in that the Fusion option in the settings only takes the camera input and forgets about the sat nav stored data if camera is enabled.
I prefer it this way as enables the virtual cockpit speed sign display, and picks up road works and is correct vs where the sav maps have not been updated.
The warning only shows up once as you said, and can be quickly cleared by a steering wheel push in the same way the headlights and personality settings warnings are.
I have an MY21 model in AU, and was a bit disappointed not to have TSR...
Did you enable it with vcds or similar, in which case I should assume that it can't be done on mine, because it's MY21 (as per other thread)?
I remove sd card
And the camera work good read sign
I can't find westbank maps
Where can i download it
Palestine- jordan- emarat-dubai- ....etc
It actually causes an additional occasional problem with mine.  Some time (30 mins + ) after startup, but not every time, I get a 'bong' and something similar to "lane assist not available" or something, accompanied with the amber triangle-exclamation warning.
It seems to me that the system notices the error state of the camera for TSR (i.e. missing map data), and some time after that a watchdog resets the entire camera module.  The module then reboots and starts working again (within about 15 seconds).  2 mins after that I get the warning about TSR deprecated same as with an engine start.  I then have to go into driver assist in the virtual cockpit and toggle the lane assist on, off and on again.  If I don't toggle it twice, it defaults back to off at next start.
I turned the settings back to the original (without TSR, MDI uses maps for speed limit signs) and that extra problem went away.  It might be unique to my car, my previous Kodiaq had the same settings for TSR and didn't have this extra problem.
I'd appreciate if you can share your settings so I can compare as there are a few different sets of config for TSR floating about.
Yes VCDS for me (MY19), and your assumption might be correct.  Disappointing if that is the case.  Hopefully the very smart people at Ross Tech figure out a way around it soon.
This is what I did.
Go into Module 5F MultiMedia
Select Adaptations, then Car_Functions_List_BAP_Gen2
Select traffic_sign_recognition_0x21, and set to Activated
Select Adaptions, Car_Function_Adaptations_Gen2-menu
Select menu_display_road_sign_identification, set to Enabled
Select Coding, and then select Byte 24, activate Bit 6 – (was already ticked in long coding)
Go into Module A5 - Front Sensor Driver Assistance
Select Coding, and then select Byte 16, activate Bit 4 (‘Traffic Sign Recognition VZE’ ->Coded)
Go into Module 17 Dash Board
Select Coding, then Byte 5, active bit 2 (‘Traffic Sign Recognition Installed’ -> Activated)
Go back into Module A5 - Front Sensor Driver Assistance
Select Adaptations, then Road sign detection fusion mode, and change to Road Sign Detection. The original was Road Sign Fusion
Enter Code 20103 to save the change
Reboot the infotainment unit
