Noise help
Hi new to this so bear with me right I have a wearing noise sound like front driver side it come on about 40 mph and get slightly louder I’ve jack car up and wiggled the wheels and they don’t wobble so does that rule out wheel bearing I had new disks and pads done in may could it be the pads sticking on maybe if I put it on axle stand and take wheels of and brakes off start it up and accelerate if it makes the same noise I take it it would be the wheel bearing any help or advice much appreciated thanks
does the noise change when your cornering?
Haven’t noticed it mate but I’m out tomorrow in the car so will listen
No idea. Where you were holding the wheel makes a difference as to whether your tested for play in the wheel bearings or the track rod ends.
