Raising my cars Suspension
Ive just changed my wheels on my skoda to a bk racing wheels 17" and its catching the wheel arch, i was thinking of rasing the suspension a little bit, is there any other way around this problem?
be nice im new to all this modding stuff and really want to get into it properly :)
You'll need to start by fitting the correct sized tyres, you need 205/40/17 on the Fabia to avoid catching the arches.
thank you bud yeh i did just go and check i have the right tyre size on the car which i dont lol pmsl. if it does still catch what should i do
If you fit the correct sized tyres it won't catch.
You can't just chuck wheels from a bigger car onto a smaller car and expect everything to be ok.
You can pull the wheel arches, which needs a bit of skill to look OK, but is exactly what it sounds like.
with the tryes can i have 205/45/17 instead of 40 wouold that make much difference
Instead of playing guessing games you could just fit the correct size tyre for the car rather than this random scrapyard modding approach.
okay so bascailly another question, would my alloy that come in a tyre of 225/45/17 fit in 205/40/17 or not
Yes.
Yes, or No, or Maybe. You haven't stated the width or offset of these wheels, and I'm only presuming them to be 17" diameter from the tyre size you're quoting.
All i know is the rims are 17" standered and the tyres the came on are 225/45/17
1 minute ago, Aaronbuxton911 said:
The rims are 17" standered
No they're not; the Fabia mk1 was never supplied with standard wheels above 16" diameter. If they're a standard or optional VAG alloy wheel, a reference like "17x6.5JET42" will be cast into them.
all i know is that they are bk racing wheels and they look like the bk racing 166
change that they look like the bk 808
And of course if the new wheel/tyre combination changes the rolling circumference, it will affect the speedo, so also bear that in mind.
Yeah, if you don't actually know what they are and can't find size info cast into the wheel rim, you're going to need to post a picture of a wheel to give people a fighting chance of finding the actual model.
