EPC and engine management light
Hi I have a skoda kodiaq tsi 2017 model, my EPC and engine management light stays on when I turn on the car. Then when I turn on the ignition/engine and when driving, it's not there and to be honest this lessen my worry. I've taken the car to my local skoda dealer and they say there's nothing wrong but I cant help feeling why the the lights are staying on, surely I should not be seeing anything, regardless.
If there are no fault lights on when you are driving, there is no fault.
Every car I’ve had, the warning lights come on when you turn on the ignition and extinguish when the engine is started.
Thanks for the reply. I've just spoken to another dealer and they said that yes when you turn on the ignition all lights will come for second and then they should all go off. He said my warning lights should not be staying on.
So have you any warning lights on with the engine running.
The engine management light will stay on till the engine is started as it can’t tell the engine is ok if the engine is not running!
Yes that's the positive, it does not stay on when the engine is running. Your right the engine would need to be on for it to detect a fault. I'm taking it to another dealer, they may say the same thing. Thanks
