Radio Code?
Hi guys I need my radio code and cant find it anywhere on any of my skoda books i got with my car not even the radio book,
I rang up my local skoda and they said your not given the radio code you have to bring it in and pay them to get it for you.
is this some sort of JOKE I have all the original books user manuals radio manuals book and they dont give you the radio code when you buy the car.
I understand you need to take the radio out to get the radio number which I find daft that this is not even in the books and seems I,m going to have to pay some guy on ebay £13 to get my code.
I mean where do them on ebay get the code they much know someone who gives it to them?
Oh do I need a special tool to get the radio out?
Edited by sealover1
Yes and no. Yes in that you need radio "keys" to remove the head unit. No in that the code for the original fit ICE is stored in the convenience ECU and read from there if required when you switch the ignition on. This almost always works, even after the battery has been disconnected or the ICE removed and replaced.
 I am resetting the ECU by disconnection of the battery and draining the power will the ECU still store it?
Edited by sealover1
  1. Stop shouting!
  2. Well, I've changed the battery, which involves disconnecting both terminals and the ICE came back about 3s after I switched the ignition back on.
  • Sponsor
If you mean the engine ECU, then I don't think you'll be resetting anything in that by disconnecting the battery. It's powered through a relay, so every time you switch off the car and walk away, you effectively remove power from it when the relay de-energises.
What are you trying to achieve by such a reset?
19 minutes ago, KenONeill said:
  1. Stop shouting!
Not shouting Ken, I have disabilities, I had to copy N Paste part of the message and when I posted it would not let me take the bold off.. thanks for the answer
Hi  Wino I was getting desperate and come across quite a few of these vids about resetting the ECU's its a bit like resetting a computer and computers I understand, I took the battery off once and it did help, so thought what have I got to lose i,m still getting lots of false codes like glow plugs, I have had a lot of my income stopped Wino and I just cant afford a garage hourly rates, I have tried garages which charged me loads of money and 2 weeks later yet another warning light or sensor warning its driving me nuts as not to well lately
lots of diff vids this is just 1 i watched of about 10 lol
https://www.youtube.com/watch?v=vYtyDX9RTWs
Sunday,11,July,2021,17:44:35:35642
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBKE21Z788009343   License Plate: NX57GHB
Mileage: 312890km-194420mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
VIN: TMBKE21Z788009343   Mileage: 312890km-194420miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 SS    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1302
   Revision: --H07---    Serial number: SKZ7Z0G4311023
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 025C73D48807A2BB997-8056
5 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
000801 - Engine Speed Sensor (G28)
               P0321 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 312251 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:08:39
             Freeze Frame:
                    RPM: 1764 /min
                    Speed: 41.0 km/h
                    Load: 26.3 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    RPM: 882 /min
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00H14001
   Coding: 0023170
   Shop #: WSC 73430 790 00000
   VCID: 698E4478957151E338D-803C
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 45D6A8C8D9A95583FC5-8010
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005018991
   Coding: E18A0F130004100000110D000000000000087F065C000000000000000000
   Shop #: WSC 07894 067 57207
   VCID: 71BE2C18BDA1A92370D-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060607 022  0601
   Coding: 00055223
   Shop #: WSC 07894
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     250607 046  0204
   Coding: 00471077
   Shop #: WSC 07894
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1A3RTX
   Coding: 0020788
   VCID: 3D26C028B1791D43A45-8068
   Subsystem 1 - Serial number: 6332MSME184A620EG
   Subsystem 2 - Serial number: 6342MSME1C044D46G
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002042
   VCID: 015E7CD88D01B9A380D-8054
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4311023
   Coding: 0007402
   Shop #: WSC 11111 067 57207
   VCID: 392ED438A551216388D-806C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 160607F2000472
   Coding: E9837F0E0002022303
   VCID: 3038E91C762BE02B3F3-8064
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3634DF04944FCE1B65F-8062
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000758
   VCID: 3828D13C9E5B386B773-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3430E50C8233DC0B5BB-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F02050FC0085F96907C00
   VCID: 035276D0971DABB3921-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Component:   Sounder No Answer
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 312898 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:42:25
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000008
   VCID: 74B0250CC2B39C0B9BB-8020
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0019189
   Coding: 0000402
   VCID: 2E04F7646C1FF6DB2DF-807A
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 372AD200934537137E9-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End----------(Elapsed Time: 01:18, VBatt start/end: 12.7V/12.5V)-----------
Sunday,11,July,2021,17:48:00:35642
www.Ross-Tech.com
01-Engine -- Status: OK 0000
   Coding: 0000172
Readiness: 0 0 0 0 1
   Revision: 00H14001
   Coding: 0023170
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
   Coding: 0020788
   Coding: 0002042
   Coding: 0007402
   Coding: 0000001
   Coding: 0000758
   Coding: 00000000
   Shop #: WSC 73430
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 312898 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:42:25
   Coding: 0000758
   Coding: 0000008
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
End----------(Elapsed Time: 01:16, VBatt start/end: 12.4V/12.4V)-----------
Edited by sealover1
well well, I followed that Video left it for an hour to discharge put the battery cables back on and boom, everything working fine again, all warning lights have gone out, no faults, nothing and radio still works.
@sealover1 - Kewel. I see it worked for you. Now, on the assumption that your engine is a 1.9tdi variant, it will run for years with bad glowplugs, and the worst effect you'll notice is a bit of white smoke for a few seconds on a cold start in Winter.
Its a Skoda Octavia Scout MK2 2007  2.0 TDI Estate Engine BMM 103kw, I dont think there is anything wrong with the glow plugs I think its false faults and a wiring problem, plus as soon as the battery runs down a bit it starts showing faults of all sorts, thing is being disabled I dont really go out much and when I do its to the shops and back, sometimes drive over to the beach but I dont do a lot of miles really and it plays havoc when the battery is not got a good charge in it. I do have a good charger so will just have to give it a charge every couple of months and see if that stops it
Mk2s and most new cars really don't like low voltage conditions, like you say.
Edit. Alarm horn fault probably due to modile fault, it's own rechargeable battery failing...
Edited by TheClient
1 minute ago, TheClient said:
Edit. Alarm horn probably due to modile fault, it's own rechargeable battery failing...
The Alarm horn  is not there lol they both went so I replaced 1 and that seems loud enough for me
Minor point, I have a 2007 1.9tdi and over lockdown found I needed to charge at least once per month to keep the voltage up, admittedly the battery was 5 years old
  • Sponsor
Yeah, when @sealover1 said 'every couple of months' my first thought was 'more often would be better'.
Alarm horn is generally a separate entity from the horn(s) that you (might) blast other motorists with.
Not sure about the horn thing then if its not the missing horn, and yes maybe your right about monthly the battery is only under 2 years old,
but then driving it this morning the 2 lights come back on and back off again a few times so maybe its not fixed, my mate said your tyres look not fully inflated and that could even cause problems and so inflated them and now the lights have not come back on yet.
am confused.com lol
Back to an earlier comment, the alarm horn, no signal will be the alarm siren unit with it's own rechargeable battery. It is either unplugged, wiring faulty or as they all do somewhere north of 6 years, probably failed due to the battery leaking.   So it is unlikely to function in a theft situation.  You can test by lowering a window on the car. Locking. Leave 30 seconds. Then waive your arms in the car, you may find the hazzard lights activate but no siren.   It will not produce any dash lights though.
What 2 lights on the dash come and go?  Low tyre pressure can cause the TPMS to show a picture of the tyre tread indicating low pressure. If it is ESC / ABS you could have a faulty abs sensor or ring which is also pretty common on these after so many years.  The VCDS scan didn't show anything other than the alarm siren and the glow plugs unless I missed something.
the alarm horn works as it does go off from time to time,
the warning lights that was showing up is the ABS and Traction control
That can happen when the alternator isn't charging properly.
Never heard of that before?...
ABS  sensor surly it would say which one? there are 4 is there not?
These are fascia warning lights illuminating, because the relevant ECU isn't receiving sufficient voltage.
if the alternator dont give out a charge dont the battery warning light come on then?
Not if the reason for the alternator inaction is:-
  1. The sprague clutch is open.
  2. One of the alternator control wires has come disconnected,
I just went out and checked the alternator  and its fine 14v with air con on lights on full so it is working as it should
