Hello people, help please
I keep getting this error when trying to update the stereo software from 241 to 253
ERROR: VARIANT CONFLICT
MEDIUM: DEVICE DOESNT SUPPORT THIS                  (MAIN UNIT: VARIANT)
can anyone activate the smart app?? without bending over at the main dealers!!
I'm sure @pab567 will be along shortly.
It might be worth confirming the full filename of the update you're trying to use too...
MST2_EU_SK_ZR_P0253T.7z
.7z is a 7zip compressed file. You'll need to extract it's content first before attempting to do any update.
i have extracted the main file, do i have to extract every single folder
Should just be able to copy all that to the SD card or usb stick to the root of whatever you are using
that's what i thought, ive tried both usb below the stereo and the SD card slot in the glove box but both give me the same error :sadsmile:
Paste here first section from metainfo2.txt
its empty, no text in the document at all
i think thats all the stereo info i could find
I think your zip file maybe corrupted in that case; might I suggest you delete it and get a new version from @pab567 if you are able.
@pab567 is the legend that gave me the link, unless someone has tampered with it.
ive just reformated the sd and redownloaded the link and it has worked :biggrin::biggrin:.
just need to get the smart link app working
For SmartLink activation you have either contact your local SKODA dealer or have the unit hacked (pls do not ask how...)
I think I'll go and see the dealer and hand over £150 rather than buggering up a £500 stereo
  • 2 years later...
@pab567 just found my old thread showing my old software, i will send across the VIN later in the other thread we are using. 👍🏼
