Exhaust temperature sensor fault
Hi . Iv a problem with my 2016 Octavia
-1.6
-mil light on / glow plug light
-live data shows exhaust temp sensor 4 at -40
my problem is location of the sensor 4
I have the location of
3 temp sensors
2 oxegen sensor
2 pressure sensors
Am I missing something or does one of the sensors act as a temp sensors and oxegen sensor .
At a guess, it doesn't have a 4th temperature sensor hence the nonsense reading :)
On my old MK2 Octavia, it had 4 exhaust temperature readings but number 2 was always 0'C...
What's the fault code you've got?
Il post in p code but it’s basically saying failed regen because of time taken
When I disconnect the 3 temp sensors that I can locate they all re act and go to a mental reading . So I was thinking -40 was a reading from a failed sensor or open circuit .
  • Sponsor
If there is a no.4, logic suggests it will be nearest to the tailpipe/ rear of car.
Access to sensor and connector may be from below only?
The last sensor is a oxegen sensor 4-6 wires
the second last sensor is a pressure sensor pipe leading up to the pressure sensor at the top of engine .
il take photos soon and post in p code going into tackle it again it’s given me nightmares at this stage .
