Abnormal left driving light warning
Hello,
every time I power up the car I get a warning, "Check left driving light" or something like that. Exception is that if I power up the car, and jiggle the light switch on-off-on-off-on at the same time for something like 5 cycles I DON'T get that warning as long as I live the switch to "ON". I can start the car and everything is just fine and dandy. I can take that beast for a 666 km ride and everything is just great - and when I say everything is just great, I mean that they're great to a certain point. That point is reached when I touch that light switch and turn the lights "OFF". After maybe 5 seconds after switching to "OFF", that warning light pops up again - "Check left driving light".
Yeah, well.. kudos to computer, bulb certainly ain't lit when the lights are off, but just.. what an earth?
So, the problem here is abnormal behaviour of warning light. Lights themselves are working perfectly. What's the deal with jiggling between on and off for numerous times - why that prevents warning to appear? Why it appears after about 5 seconds when I turn the lights off? And most importantly, how to fix this? It's more a nuisance than anything else, but that just bugs the life out of me.
I haven't tried new bulbs yet, but I switched right bulb to left and vice versa and nothing changed. I also tried some contact spray to bulb's base (what ever it is called?) and to light's wiring itself, but that didn't help. Any ideas?
I find the lead solder wears away on the bottom of my bulbs due to vibration on both my cars.
On the bulb itself, or do you mean that plug/socket (I don't know what it's called) where the bulb goes?
on the end of the bulb
Okey, I do appreciate you answering, but I don't think the bulb itself is faulty in anyway. Nothing changed when I swapped right and left bulb.
is it the actual light switch you have to jiggle or the steering wheel stalk?
i presume the main light switch.
take out the switch unit and check all the contacts for corrosion and frayed wires. give the plug connectors a good clean with the electric contact cleaner and a cloth. put it back in a see if it makes any difference.
Thanks for your reply. That may indeed be the way to go.
You presumed right, I have to jiggle main light switch. I noticed now, that when I turn the lights OFF, then the right fog light is actually lit. I hope that switch is easy to remove! VW Polo seemed to have mechanism for easy removal - I hope that applies to Octavia 2 too.
yup, mechanism is the same for all of them. middle, push in, twist, pullout
Visually the switch was just immaculate. I'll probably try replacing it nevertheless. Maybe I should try checking right fog lamp too.
Oh and just food for thoughts, could this be something that some fault code reader could deal with it? Could this be just a glitch somewhere?
  • 2 months later...
Well, I don't know if anyone is interested, but to give a conclusion: it was battery. 5 minutes with code reader drained it.
