Instrument cluster
I have a skoda fabia Mk1 2006 1.4 tdi and wanted to know if I changed the instrument cluster on my car does the replacement instrument cluster have to be reprogramed I'm only asking as my cluster has a fault and I'm unable to repair it myself.
  • Sponsor
Did you try reflowing any connector joints?
I can tell you the relevant pin numbers if it helps; or even do it for you if you can be without the cluster for a few days.
Don't think it's plug and play, there may be some immobiliser problems but not too sure.
Thanks for the reply I took the cluster out and looked but to be honest it's to fiddly for me to do where abouts in the country are you if you don't mind me asking I myself am in Chesterfield Derbyshire.
Yeah, cluster can't be swapped without having the immobiliser programmed.
Thank you for the reply and answer.
  • Sponsor
I'm in Oxfordshire so you'd have to post it, but I could post it back same day as I get it. Pins 15 and 32 of the green connector are the only relevant joints to check/reflow for the fuel gauge, I think.
Edited by Wino
Would you happen to have a picture showing which pins it is.
Edited by TMB
^ That's a pic of the pins. Ignore the big yellow arrow, that's the immobiliser pins.
Edited by TMB
From back of cluster....
Edited by TMB
  • Sponsor
Or in this view...
So front row leftmost is 32, back row 2nd from left is 15.
EDIT. Wino beat me to it :thumbup:
Edited by TMB
Thank you so much guys I really appreciate it you have been a great help.
