power to engine bay
hello, can anybody tell me where i can find a grommet that links through the fire wall of a fabia 2010 , please.
its to run 12v wire through.
thanks.
What's the wire for?
Check my post from last week
its to power sequential led strip
I don't think you need to go from the engine bay then just go from the fuse box panel under the steering wheel. There are lots of spare slots on the fuse panel.
it needs to go from the fuse box to the engine bay, because they are led come indicator lights, maybe i had explained not very clear, and i don't which to drill any holes in the fire wall
Ahh ok so you can use the the same method as I did.
Take off windscreen wipers (13mm socket)
Take off scuttle plastic cover (10mm)
Take off wiper mechanism. It comes off in 1 whole unit. (10 mm I think) Unclip the harness pull the unit away from the positioning pin and then wiggle and to to get it out from under the ledge.
Behind the mechanism you will see the plastic panel shown in picture of the other post. Look at the wiring harness and cut a very small hole in the nipple. Use a very thin rod , stick, or coat hanger and put some white or yellow tape on it so you will see it easier when you are looking for it in the car. Put some grease or sliding silicone on it to help it side past the rubber and other wires. Attach your wire to end of it.
Slide the driver seat right back.
Look up under the steering wheel to see the main wire loom coming from the engine bay fire wall. Once you have pulled it through clean off your sliding agent and then use some rubber sealant around where the hole is at the nipple.
