What tyres did you get?
4 hours ago, zetzet said:
Wheel caps are center caps, they are probably mentioned separately, because you can buy them separately to replace broken/lost ones.
Agree on this one. Wheel caps are the plastic thingies over the bolts.
  • Replies 57
  • Views 14.2k
  • TheUltraRunner
    TheUltraRunner
    VRSs are shipped only with two sizes of wheels. 18" are 225/45/18 and the 19" are 225/40/19. If I would be buying a VRS now, I would probably go with the black 18" wheels and used them as a winter set
  • Sorry, but i have them on my car. It is solid wheel.
  • DaveFromSydney
    DaveFromSydney
    Bridgestone, Potenza S005. 225/40 R19 93Y. 021/02/28. Made in Hungary.   Car was delivered to me 30/05/2021.
 Skoda should word it all better so also when translating it should be beter understood. In my case the dealer does not know and has to inform himself, so still waiting on that.
They should say - Wheel center caps , - Bolt cover Caps.  then it is clear as day. The Vela, vega stuff should have been tought over better and make the same possibilities.
Well removable "aerodynamic wheel covers" are not very common. It's quite normal to think they don't exist :)
Very common with a Tesla.
 Lets call them 'Wheel Trims that do not need zip ties to keep them on.
Edited by e-Roottoot
  • 4 months later...
For those who got a car with Goodyear Supersport tires.  What they have shown you in terms of endurance?  In the spring I will buy new 19 "tires so I am in doubt which tires to choose, Michelin Pilot Sport 4S, GY Asymmetric 5, Potenza Sport? Can anyone give a first hand recommendation?
Edited by Bomber987
Hi Bomber . GY F1 SS up there with PS4S , Conti 6 downside , they wear fast on the VRS. Mine are just at 3mm with 8.5k.
I replaced the fronts yesterday with F1 Asymmetric 5's due to better wet handling. I would also look at the Hankook evo 3 , just came first in an autocar mag test. The Bridgies are getting good reviews but ive never had a set that i liked.
All in all 4s can t go wrong , save some cash A5's the only noticeable diff would be on track
Thank you for your reply.  I drive about 35,000 kilometers a year, of which 70% are highways.  I'm not going to the tracks (at least for now :) ).
7.5k miles has seen less than 1mm reduction of tread depth on the F1 A5's i've got on mine, so project that across a worst case scenario i should be seeing at least 22.5k (if i had any intention of having the car that long at the moment) on these before needing to look at replacements.
