Diesel mixed with coolant
Pls give me soluction for my fabia 1.4 TDI 2007 model. Diesel mixed with coolant.
I'm afraid you'll need to give more information than that.
 - Approx mileage
 - Where is the mixed diesel coolant showing
 - Pictures of the level of coolant/fuel mix
 - Are you sure it's fuel and not oil?
 - Any diagnosis you've had carried out by a garage/mechanic etc.
- Which coolant are you using
- Any other symptoms, such as leaks etc.
50:50 shaken in a sealed container, if you dont use it all straight away shake the remainder to mix again before using again.
Edited by J.R.
Is there diesel in the coolant tank then?
Does your car have a Webasto preheater installed?
