Date/time setting
I noticed while driving today that the time was incorrect on the (Amundsen) screen.  I went into settings, and it was set for GPS adjustment, so I changed it to manual, and reset, no problem.
Was this as a result of simply losing gps signal, and if so, will it happen every time, and presumably ‘catch up’ when the signal is picked up again?
Thanks in advance
Edited by Baxlin
This is a common problem and I'm not 100% sure what triggers it, nor is there a 100% solution to get the time back in sync by leaving the setting on GPS adjustment. However I can tell you it does eventually automatically resolve itself if left on the automatic GPS setting.  A strange quirk 😛
Edited by RB79
Yes. One which is resolved by a firmware update. Version 0480 seems to fix GPS wobbles.
