Michelin Cross Climate 2 (replaces cc plus)
  • SurreyJohn changed the title to Michelin Cross Climate 2 (replaces cc plus)
6 hours ago, SurreyJohn said:
Michelin has released the CrossClimate 2 in Europe in 107 sizes
It's actually 66 sizes, not 107 sizes as shown below. However, the CrossClimate 2 is often available in more than one version of each size such as different speed ratings and load indexes making a total of 107 different versions:
15" Michelin CrossClimate 2 (7 Sizes)
175/65 185/60 185/65 195/55 195/60 195/65 205/60
16" Michelin CrossClimate 2 (18 Sizes)
185/50 185/55 195/45 195/50 195/55 195/60 195/65 205/45 205/50 205/55 205/60 215/45 215/55 215/60 215/65 225/50 225/55 225/60
17" Michelin CrossClimate 2 (16 Sizes)
205/45 205/50 205/55 215/40 215/45 215/50 215/55 215/60 215/65 225/45 225/50 225/55 225/60 235/45 235/55 245/45
18" Michelin CrossClimate 2 (12 Sizes)
215/40 225/40 225/45 235/40 235/45 235/50 235/55 235/60 245/40 245/45 255/45 265/35
19" Michelin CrossClimate 2 (11 Sizes)
205/55 225/40 235/40 235/45 235/50 235/55 245/35 245/40 245/45 255/35 255/40
20" Michelin CrossClimate 2 (2 Sizes)
195/55 275/45
Edited by Carlston
Bonnie Scotland.
(During Lock Down, Ski Centres closed to anyone other than from that Region)
19 hours ago, SurreyJohn said:
Unfortunately not available in 215/45 R18 fitted to my Arona, and used on Kamiq.
225/45R18 could be used instead of 215/45R18.
225/45R18 has a 0.4% bigger outside diameter than 205/55R17.
The Octavia MK3 uses a 7J rim width for it's 225/45 tyre and the Kamiq uses the same 7J rim width for it's 215/45 tyre.
Skoda Octavia MK3
Tire
Rim
225/45R17 91Y 7Jx17 ET49
Skoda Kamiq
Tire
Rim
215/45R18 89V 7Jx18 ET39
Edited by Carlston
Skoda Octavia MK3
Tire
Rim
Skoda Kamiq
Tire
Rim
Yes I agree that could put a different size on Kamiq (and Arona and T-cross)
But they still come with 18 inch rims in UK, so have to buy extra rims if you want smaller wheels.  Surely 225/45 R18 is about 1.6% bigger than 215/45 R18 and is too big for spare wheel well.
So although there are ways around, the default size is rather annoying as it is limited in all season.  It seems vanity has overtaken practically as same engines get 16 or 17 inch wheels elsewhere so clearly don’t need the non-standard tyre size 18s.
With at least different models getting 215/45 R18 do have to wonder why Michelin didn’t make that size.
Outside diameter of 225/45R18 tyre is 659.7mm
Outside diameter of 205/55R17 is 657.3mm
Outside diameter of 215/45R18 tyre is 650.7mm
So 225/45R18 has a 1.4% bigger outside diameter than 215/45R18.
But if you compare the 225/45R18 size to 205/55R17 (another standard tyre size) the difference is only 0.4%.
The difference between the outside radius of a 225/45R18 tyre and a 215/45R18 tyre is 4.5mm.
The difference between the width of a 225/45R18 tyre and a 215/45R18 tyre (when they are both fitted to a 7J rim width) is about 7mm NOT the 10mm which you might expect.
PROXES COMFORT
Developed to provide premium levels of stability and comfort for relaxed driving experience.
  Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch)
zoom-icon.png 215/45 R18 93W XL 7.5 651 213 7.0-7-8.0
PROXES COMFORT
zoom-icon.png 225/45 R18 95W XL 7.6 659 225 7.0-7.5-8.5
Notice that the above 225/45R18 chart shows the tyre width when fitted to a 7.5J rim, but if fitted to a 7J rim it will only be about 220mm in width, ie. only 7mm wider than the 215/45R18 tyre.
https://www.toyo.co.uk/tirefinder/index/width/225/aspect/45/rim/18
Edited by Carlston
Be interesting to see how these compare to the current competition.
New car test dropped.
