Q : Tweak the coming/leaving home function... ?
Hello !
My car has the coming/leaving home function already installed and activated from the factory.
The problem is that it is the Xenon low beam that lights up.
(The fog light does not come on.)
❓  Is it possible to code with VCDS and change/switch function so that it is the fog lights that are lit and the low beam not come on ?  ❓
Yes, you should be able to change this in adaptations under central electronics
Can you explain in a little more detail how to do once you have entered that place ?
Edited by 2stroke
Start by posting an autoscan so we can see what your car is made from and offer any relevant advise... :)
2021-09-13
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
Dealer/Shop Name:
VIN: TMBKK61Z3C2064867   License Plate:
Mileage: 147700 km   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 69 72
VIN: TMBKK61Z3C2064867   Mileage: 147700 km
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0203000C180F0160
   Shop #: WSC 73430 790 00083
   VCID: 353726C2C9431DC36C5-8060
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 113B401C0A2800FE881302EA50200041310000
   VCID: 7BA3F0FAA3E70BB3DA1-802E
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7DA7FEE2BD730583E45-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 40000AB8E00508C040080084510011A4437000AE726D8D605CC540000040
   VCID: 3FDB44EAF77FD793B69-806A
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 20091  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150911 05  54  0403
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 75461125900531
   Coding: 118010
   Shop #: WSC 13765 790 00083
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 333318DACBB703F3421-8066
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2SZFTT
   Coding: 0020790
   VCID: 3D273EE2F173C583A45-8068
   Subsystem 1 - Serial number: 6332MSME623354554
   Subsystem 2 - Serial number: 6342MSME6513211A1
   Subsystem 3 - Serial number: 6351HSME291618745
   Subsystem 4 - Serial number: 6361HSME287B72319
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110907300607
   Coding: 1082140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFEAF2A95B39A3C8D-802C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 843 Q    HW: 1Z0 920 843 Q
   Component: KOMBI         H05 0607
   Serial number: 00000000000000
   Coding: 120E00
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 46D5510EA825865BF5F-8012
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 140911F1001174
   Coding: 352302
   VCID: 353726C2C5431DC36C5-8060
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   Shop #: WSC 00000 000 00000
   VCID: 45D7560299A38D43FC5-8010
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0607
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DC5BEDCFD823B317-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0004342
   VCID: 76B5E1CE94C556DBA5F-8022
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 34311BC6C23904CB5BB-8060
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004342
   VCID: 48C95F36AEB1902B073-801C
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1507354
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000023
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        010 0061
   Revision: 0A001001    Serial number: SKZ1Z3L9543733
   Coding: 0F0004000001
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012563
   VCID: 323D1DDE382D0AFB497-8066
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00000155230775
   Coding: 410D000100000000
   VCID: 303917D63A2138EB3F3-8064
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 333318DAC73703F3421-8066
End----------( Elapsed Time: 01:12, VBatt start/end: 14.3V/14.2V )-----------
Try changing byte 17, bit 3 in 09 (Central Electronics) :)
Should be called coming home via fogs active or similar IIRC :thumbup:
Can you explain in detail how I perform/do this ?
( I'm a VCDS newbie )
What does IIRC mean ?
IIRC means "if I recall correctly".
As for how to do this...
go to 09 (central electronics) then change the coding/long coding.
There will be a series of hexidecimal fields value would be anywhere from 00-FF IIRC.  The 17th or 18th one along will probably have some check boxes below where you can enable the function.
Remember to take note of any changes you make.
If you are still quite new to this - look up some VCDS tutorial videos on youtube and don't do something you're not confident doing and understand that there are risks involved (that could result in you breaking something).
oh and from another thread:
Quote
PLEASE DO NOT ATTEMPT TO ACCESS Byte 18 of the 09 Central Electronics Module of a BCM with VCDS.
The coding is behind the 00 mask for a good reason - to stop folk playing around with it.
Accessing the 00 mask, and changing anything in there is a dangerous thing to do - nobody knows what the coding is in there, and if it goes wrong, returning the coding to 00 WILL NOT restore the coding to the original, and will cause all sorts of issues. The member concerned attempted recoding for rear DRLs but what he thought was the correct coding didn't work - and re-entering a 00 code has not restored it to what it was. He now has one rear tail light and one reversing light permanently on with the ignition and the car will no doubt have to go into the dealers to have things reset.
