Matrix light on superb 3
Is there a genius on matrix headlights out there ?
Can the long light be adjusted without the short light included?
Please help a superb driver in denmark 😀
I’m no genius, but I’ve have the same issue with the dark field between low and high beam (as I assume you do). I’ve searched every forum I have found, and have had the car at the shop two times. The answer from Skoda is that the beams cannot be adjusted individually…
My solution was to install a LED-bar, because I was going crazy when I used the high beam.
Do you have any picture to share? I'm curious to see how it looks like. :)
The bar is installed behind the air intake, so you don’t see it if you don’t know it’s there.
It was hard taking good pictures with the high beam on. But you get an idea of how it looks.
