Yeti Suspension- Number
Hi, I am in between replacing my front suspension struts. Got a doubt that "Front struts are mirror to one another( part with different numbers) ? or same part number for both sides" ?. Anyone changed front struts, please help.
             Yes both shocks are the same .
Its the stubs that carry the shocks that are handed.
Don't forget you will need a coil spring compressor tool to remove them from the springs.
Heavy Duty Coil Spring Compressor Hook Strut Clamp Suspension Car Auto Tool
Hi Urrell, Thanks for the reply. I bought equivalent item for  3C0 413 031 BC. its mentioned as 2 numbers. image.thumb.png.71eefb3035cf0889183791a1a53ec780.pngthe attached
This is the B4,s i bought . The marked holes are to connect the stabilizer link. If its not mirrored it will twist the antiroll bar in a parallel road itself. right ?IMG_20210922_181236448.thumb.jpg.fc8700bc83b34ac061e91d7384a0d5e8.jpg
Yes, they are both the same.
Do one side at a time it will soon workout ok.
Recommended, replace the coil springs as well whilst your there.
The state of our roads are appalling what with pot holes & the like, so would be a good idea.
Edited by Carlodiesel
Thanks Carlo. I will try it.
Update: Strut installation done. Working fine. Acts stiffer than OE strut.
