wheel question.
offset probably wrong , aren't VRS rims ET37 or 38 , those are 48 , the pcd is correct but is the wheel hub centre the right size ?
Offset is way out, also hub cente is a different bore.
this may sound like a stupid question but what does ET37 mean?:(
ET is German but it means that the mounting face of the wheel is offset from the centreline of the wheel by "nn" (37, 48 etc) millimetres. Positive numbers mean the mounting is offset towards the face of the wheel, negatives, towards the suspension struts IYSWIM?
You'd need wheel spacers in order to use them and the spacers would probably be 8-10mm thick. Though I don't know how much clearance there is behind the standard alloys.
J.
Make - Skoda Model - Fabia Year - 00> PCD - 5x100 Offset - 30 to 45 Bore - 57.1
Recommended fitments, 14" 1856014 15" 1955015 16" 2054516 17" 2054017.
Viewing results 1 - 5 of 69 for 17" 5x100 et30,5x100 et33,5x100 et35,5x100 et37,5x100 et38,5x100 et40,5x100 et42,5x100 et45,5x100/57.1 et35
this info is for a fabia wheel fitment from this website.
http://www.alloywheels.com/search.asp?numrecordposition=1&strSize=17%22&strkeywords=5x100%20et30,5x100%20et33,5x100%20et35,5x100%20et37,5x100%20et38,5x100%20et40,5x100%20et42,5x100%20et45,5x100/57.1%20et35&strSort=Low&Make=Skoda&Model=Fabia
so does this mean that the size your on about is 30-45 for the fabia?:confused:
daz
