Octavia 2007 II Combi (1Z5) 2.0 TDI PD vRS 125KW 170hp: Job List - Break disks, pads, callipers, shocks. All round. DIY - Please advise
This post was recognized by ColinD!
MrZakalwe was awarded the badge 'Great Content' and 10 points.
OK... First of all just want to big up Briskoda this has very quickly become my go-to for all things Skoda!
Second I apologise for the long letter I am not skilled enough to keep it short.
Last Dec 28th I purchased a sensible compromise SKODA Octavia 2007 FWD II Combi (1Z5595) 2.0 TDI PD vRS Diesel 125KW 170 hp
I didn't actually expect to fall in love with the thing but that is exactly what has happened!!
I have some issues I need to resolve before my first MOT in Dec.  I am stuck in the house so plan on doing as much as posable for myself  (I'm no machinic but not work shy either)
I have 3x service reports (see attached), first was from JBS (VAG Specialist in Chesterfield), other two from local garage after wheel/tire changes (18 inch OEM Zenith all round).
I think I can split my ToDo list into two sections, First section would be getting suspension and breaks back up to standard. I'm on Universal Credit at the moment (So poor), however, I want to do her justice as best I can.
Judging from the service lists the MUST DO's include:
N/S/F - CV Boot
O/S/F - Lower ball joint boot
N/S/R - Break calliper seized
O/S/F - Break wear indicator - wire/harness broken
O/S/F - Disk rusted
However, what I would like to do is replace/upgrade as much as possible, especially whilst I'm there removing stuff would be nice to simply replace the lot. Break disks, pads, callipers, boots, shocks.  All round.
I have looked through previous posts (36 pages containing brakes) to see what options are best. Rather than purchasing individually all the parts it makes sense to look for a kit on eBay for example which dramatically reduces cost, also with this being VAG I can look at multiple options from a verity of other cars, this makes part hunting a little tricky (Looking up parts using Car model/REG/VIN for example is severely limiting my search options), or I could look at refurbished/brokers (Porsche stuff looks tasty for example).
I have located the build code sticker (see attached), and using prsearch.planetvag.com the xl is also attached. The only code I can see relating to disks is 1KP Rear Disk,  I was expecting more info with a range of several codes like in the post quoted and no mention of front so am I reading sticker correctly?
I have measured my current disks best I could
CURRENT SET UP:
Bolt Hole Circle PDC: 112 mm
Cantering Diameter: 65 mm
Number of holes: x5
Front
Dimeter: 312 mm
Thickness: 25 mm
Rear
Dimeter: 286 mm
Thickness: 12 mm
I have located some markings (photos also attached) no idea which of the markings are relevant / of use??:  It would be great if I could identify what callipers / shocks I'm currently using?
Front calliper
Markings - VW - Audi badges
Markings - 741
Markings - 581
Markings - VL or 7A
Markings - 131-6
Rear calliper
Markings - JK5FD
Front shock absorber
Markings - VW BS
Markings - 26H6H3
Markings - VWA 1T0413031DS
Rear shock absorber
Markings - K08D06
Markings - ?0 513 029 GB
Markings - E3103502
Markings - ?CZECHI ? AT OR OPEN
Markings - HM 5560
Coil Springs
O/S/F - New - Feb 2021
N/S/F - Old - RH3941 - 2018
O/S/R - Old -
N/S/R - New - Sep 2021
If I have understood correctly the range I want to be searching for on Disks are as follows??
Front Disks
Dimeter: 312 mm or 340 mm
Thickness: 25 mm
Height: 50 mm
PR Number Range: ?? / ??
Rear Disks
Dimeter: 286 mm or 288 mm
Thickness: 10 mm or 12 mm
Height: 48 mm or 49 mm
PR Number Range:  1KP / ???
I'm finding it more difficult to identify what measurements part numbers I should be looking for with Callipers (fore example 4 Pot, 8p 8v, ATE, TRW, VBT, - and a whole other bunch of acronyms that I don't understand)
Front Callipers
Calliper Type:
Diameter 1 mm:
Brake disk thinness:
Manufacturer Restriction:
Material:
PR No.:
Carriers: ??
Rear Callipers
Calliper Type:
Diameter 1 mm:
Material:
PR No.:
Carriers: ??
Front Shocks
Absolutely no idea
Rear Shocks
Absolutely no idea
Once again I sincerely apologise for the length of this post, but if I can just nail down my search criteria and the different ranges so I know what parts are available and which parts will complement each other?
Fore example I thought these would fit, however, the eBay Compatibility says that they do not fit 😕 ?
Skoda Octavia Mk2 04 on Diesel inc vRS Prosport Coilover Kit | eBay
MINTEX FRONT REAR DISCS PADS FOR SKODA OCTAVIA 1Z 2.0 TD VRS 170HP 2006-13 OPT2 | eBay
Skoda Octavia VRS 2005-2013 Full Set of Brake Calipers ( RECON / REMAN SERVICE) | eBay
Easy Fit Universal CV Boot Kit Drive Shaft Repair with Clips and Grease | eBay
UNIVERSAL SPLIT BALL JOINT TRACK ROD END RUBBER DUST COVER KIT FITS ALL CARS | eBay or Lower Ball Joint Pair for SEAT LEON Mk 1 1M + TOLEDO Mk 2 + SKODA OCTAVIA Mk1 1U | eBay or SKODA OCTAVIA MK2 FRONT 2 BALL JOINTS 2 ANTI ROLL BAR LINK 2 OUTER TRACK ROD END | eBay
Just as examples
Any help, advice, will be greatly appreciated!!!
Once I have my parts lined up for this first section I need to look into the second half of my ToDo which is tackling the engine warning light,  break wear indicator - wire/harness cut, Vacuum pipe missing from ERG valve, Fault on MAF sensor... I strongly suspect previous owner has either blanked or disconnected several engine parts and will require further investigation to see what is going on under the hood.. Ill save this for another day another post :)
Kind regards
Ricky
Edited by ColinD
My budget is around £600, i could stretch that if any parts are worth the extra
Front Springs 1K0411105DB
(1) 1K0411105DB coil spring
1 paint mark
1 paint mark
1 paint mark
red
white
violet
Model data: PR-L58
Front Shock Absorbers 1T0413031HP
(8) 1T0413031HP gas shock absorber
Model data: PR-G07+2UC+
L55,L58
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2007/drive_standart/419/hg_ug/411/subcategory/411020/part_id/0/lang/e
Front Brake Calipers ATE 1K0615123F 1K0615124F
(1) 1K0 615 123 F brake caliper housing
red
left
painted
1 PR-1LL
(1) 1K0 615 124 F brake caliper housing
red
right
painted
1 PR-1LL
Front Brake Discs 1K0615301AA
8 1K0 615 301 AA brake disc (vented) 312X25 5/112 2
Front Brake Pads 5K0698151
15 5K0 698 151 1 set: brake pads with wear indicator for disc brake
free cable ends
must be isolated
front 1 PR-1LP,1LL
https://skoda.7zap.com/en/cz/octavia/oct/2007-419/6/615-615030/#15
Rear Springs 1K0511115BS or 1K0511115BT
(1) 1K0511115BS coil spring
1 paint mark
2 paint marks
rear
blue
yellow
Model data: PR-1JC+0YC
(1) 1K0511115BT coil spring
1 paint mark
3 paint marks
rear
blue
yellow
Model data: PR-1JC+0YD
Rear Shock Absorbers 1K0513029GB
7 1K0513029GB gas shock absorber
for sports suspension
rear
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2007/drive_standart/419/hg_ug/511/subcategory/511031/part_id/2562471/lang/e
Rear Brake Calipers TRW 1K0615423P 1K0615424P
(1) 1K0615423P brake caliper housing
red
left
painted
Model data: PR-1KP
(1) 1K0615424P brake caliper housing
red
right
painted
Model data: PR-1KP
Rear Brake Discs 1K0615601AD
7 1K0615601AD brake disc 282X12MM 5/112
Rear Brake Pads 1K0698451G
10 1K0698451G 1 set of brake pads for disk brake rear
260X12MM
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2007/drive_standart/419/hg_ug/615/subcategory/615062/part_id/2550123/lang/e
Build Codes
G07 = Front shock absorption
2UC = Sports version
L58 = Suspension range 58 installation control only, no requirement forecast
1KP = Disc brakes, rear
Edited by Carlston
Carlston, you are an actual living legend!!
Thank you so much... I will update the post with my shopping list and let you know how i get on using this info.. So chuffed!
Kind regards
Ricky
