Spare wheel
mattdoombar
Hi guys,
just bought a cracking little 2013 sport which has the optional 16” alloys on which look mint.
sadly there is no spare wheel and I would like to add one for peace of mind. I’m assuming a full size 16” alloy and tyres will not fit in the boot space.
my query is will a 14” space saver and tyre be the same rolling radius?
if not what size space saver do I need.
cheers in advance
Any* sensible wheel that will bolt onto your hubs will fit in the wheel well  - the wheel diamater is not the issue, it's the diameter of the of the wheel+tyre assembly that counts.
*You will need to stick with a wheel/tyre that has about the same circumference as the existing wheels. If you don't, then ABS and stability controls won't work correctly!
You can get a 14" wheel (and then tyre) as you say, with the same rolling radius, but you could get a 15" or 16" alloy or steel wheel that would mean no 50mph or distance limits...
Edited by freemansteve
175/65R14 tyre size on 5Jx14 ET35 4/100 57.1 steel rim would match up well to a 195/45R16 as they both have about the same outside diameter and 175/65R14 is a standard size on the Citigo.
Outside diameter of 195/45R16 is 581.9mm
Outside diameter of 175/65R14 is 583.1mm
165/70R14 tyre size on 5Jx14 ET35 4/100 57.1 steel rim would match up well to a 185/50R16 as they both have about the same outside diameter and 165/70R14 is a standard size on the Citigo.
Outside diameter of 185/50R16 is 591.4mm
Outside diameter of 165/70R16 is 586.6mm
One of the following two OEM part numbers could be used to order a suitable steel rim from a Skoda dealer:
1S0601027
1S0601027G
(1) 1S0 601 027 steel rim
additionally to be used items:
5JX14 ET35
5
1 PR-1G1,1G2
  1S0601027  03C rally black     2010.11...
(1) 1S0 601 027 G steel rim
5JX14 ET35
5
4
  1S0601027G 03C rally black     2010.11...
https://skoda.7zap.com/en/cz/citigo/cit/2013-727/6/601-601012/
mytyres also list this specification of steel rim
ALCAR 6795
https://www.mytyres.co.uk/rims/details?vehicleId=185747096349971044&rimCode=ALCAR6795
Skoda Citigo 2013 1.0MPI 60PS
Tire
Rim
165/70R14 81T 5Jx14 ET35 2 / 1.8
175/65R14 81T 5Jx14 ET35 2 / 1.8
185/55R15 81T 5.5Jx15 ET41 2 / 1.8
185/50R16 81T 6Jx16 ET43 2.1 / 2
Skoda Citigo 2013 1.0MPI 75PS
Tire
Rim
175/65R14 82T 5Jx14 ET35 2 / 1.8
195/45R16 84H 6.5Jx16 ET38 2.1 / 2
https://www.wheel-size.com/size/skoda/citigo/2013/
Edited by Carlston
