Airbag error
Hi,
Had this error come up today.
I noticed that there was a bit of a scratching noise when steering (coming from the airbag cover) the other day but it seemed to go away by itself.
Reversing in a car park today, I steered to full extent and heard a creakin/scraping noise from the steering column again but it was more pronounced. Then, the "airbag error" came onto the dash.
Key cycled a few times and it's still there.
Has some wiring/contacts been damaged?
Any recommendations?
It's in for major (4th) service + MOT on the 18th Nov with the Skoda dealer.
Thanks in advance
Just read elsewhere on here that it may be a clock spring problem. Are they common?
It did sound like something getting mangled inside the wheel when it happened
Yup, sounds like the culprit.
Is this a dealer repair job or something I could do?
Any idea on the cost of the part?
I read elsewhere that the repair was ~£160 but I don't know if this was a dealer figure.
They are a silly price, DIYable but will need coding with VCDS, they often can be repaired with some patience, determination and a soldering iron.
I'm not averse to a soldering iron but don't really fancy a DIY repair on a safety critical component. I'll assess the damage that the dealer wants.
Thanks for help
Edited by briscaF1
Same happened to me a few weeks ago exactly. Its the airbag clock spring and it was replaced under dealer warranty but invoice said £160 all in.
