DRL with stripes
Hi al does anyone know if I can code my Octavia 3 f/l so the stripes/eye lash lights can be coded to come on with the DRL’S please
cheers
Hi, yes you can try this.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select – Leuchte 16BLK SLB35BLK SL KC9
4 - Sub – Lichtfunktion C 16
5 - Change value to Tagfahrlicht (Daytime Running Light)
6 - Set Dimmwert CD 16 to 127
7 - Select – Leuchte 17TFL R BLK SRB3TFL R BLK SR KC3
8 - Sub – Lichtfunktion C 17
9 - Change value to Tagfahrlicht (Daytime Running Light)
10 - Set Dimmwert CD 17 to 127
Wow looks complicated lol but thanks
It’s not complicated. Have a look at all the menus and settings mentioned first. A dry run. Then crack on. There is an audit trail of changes but it’s definitely worth making a backup prior to changing anything.
  • 10 months later...
2 - Adaptation
Would this be the same for a pfl?
  • 4 weeks later...
This is pfl octavia.
