Sat Nav Question
Just a query bought our Fabia MK3 estate 1.0 TSI SE  in 2019 just over 2 months old ,sat nav had an SD card installed  and only used it a few times as we know most places where we travel to, but worked fine telling you 2nd exit third exit etc at the correct lane/road that you required,  the car went in for a 2nd year service in August this year at a SKODA dealership, we have not used the navigation until the other day  but have now noticed that when approaching a roundabout the sat nav tells you to take the third exit instead of the second one as the previous ne did  it's like it's counting every lane at the junction and when there's an exit and entrance lane (small island in the middle) and a double exit straight on road it tells you to take the forth exit not a problem around roads you know but confusing if travelling some where you don't, know very well, contacted the dealership and they just said they are all ;like this but it wasn't like this before taking it in for a service just wanted to check are other Fabia's doing this with the sat nav system or did they updated  system and now it's an  "improved system"  NOT
The state of map updates on your car might be found here, if it is new enough:
https://updateportal.skoda-auto.com/en-GB
There may even be a clue there to a problem - is your SD card 32 or 64GB?
Is the satnav update mentioned on the service sheet / work done from the second year service?
The link says the update is chargeable, so if they did it you should have proof, and have some leverage with the dealer.
I'm not convinced that "they all do that" (now), but I have had a satnav in the past which did (not Skoda)
