the truth about electric cars
5 minutes ago, Evolution13 said:
Misleading people getting an EV into believing that a 50 kW battery car is going to go 250 miles or more is pure misselling. When 200 miles sometimes might be possible in the right conditions. Sadly people believe brochures and sales staff.
Sadly, the entire EV industry is guilty of misinformation, and it starts right at the top with the legislators pushing towards an idealistic goal long before we have all the answers, a pattern that I have witnessed before. I don't really think that we can lay the entire blame at the motor trade's feet when they themselves are staring down the barrel of punitive fines for noncompliance with an over-optimistic mandatory target.
Also, sadly, the education system has been dumbed down so much that almost every school leaver qualifies to get a place at university, hence why we find graduates stacking shelves in supermarkets, as industry chiefs know that the qualifications gained in a lot of cases are inferior to those gained years ago.
Edited by Graham Butcher
  • Replies 12.9k
  • Views 824.8k
  • Their efficiency at any speed is more than double that of an internal combustion engined vehicle.   The improvements in aerodynamic efficiency have pretty much all been made in recent decade
  • So surely you should be welcoming Graham's interrogation of the data and news items?   There are clearly many false statements being made on both sides of the fence...   so a balanced discus
  • Latest I've seen about cause of FH fire   https://www.electrive.com/2023/08/14/it-wasnt-an-ev-that-caused-the-fremantle-highway-to-catch-fire/
Can be done, ie get WLTP range and more, only happens in exceptional circumstances ie battery over 15C and a driver who knows how to maximise regen. My son just drives our EVs, doesn't play with the regen paddles, draft that Transit van doing the 60 mph or so and that is fine but he's a smooth driver so get quite good milez per KWh.
The Mini EV progressively throttles power and is better than the Renaults for the novice but I don't think it will go much beyond 0%. The Renaults will go more the 5% past 0% before even warning of performance restriction. It will then go another 2 or 3% before conking out so my little 5's range in summeris over 200 miles and the Scenic is over 275 miles in truth before Restriction warning pops up and one really should charge up.
EVs BMS needs to be better and more consistent across the makes as the vary massively in how they inform and perform in the lower gentiles and negative of informed state of charge.
Yes, we accept that it is possible on a good day with the right conditions and the right support just as this diesel powered Skoda Superb managed to drive for 1,759 on one tank of fuel and it set a Guinness World Records record.
Record-Breaking Skoda Does 1,759 Miles on a Single Tank
Greatest distance driven on a single tank of fuel | Guinness World Records
Superb still has a good sized tank ie 66 litres, and has not suffered so much of the trend of smaller fuel tanks on B and C segment cars.
Cars was modified with non standard tyres ie more energy efficient ones, had the Greenline smooth underfloor, something EVs have as fairly standard now and who knows what else. Probably cooled fuel to reduce volume ie put in a fridge before the run and the absolutely brimmed like I would do when I use to get my Tescos 5p /8p off tokens. Still and impressive mileage and especially as set on roads and not track like when an RAF team near doubled the miles travelled compared to WLTP ie over 480 miles compared to 250 miles WLTP but that was done at Thruxton and average speed was 20 mph not not really practical and therefore must have taken nearly 2 days, must have been a lot of fun, not.
Couple of other points. Diesel is 2.25 Euros per litre so fuel tank would cost about 150 Euros to fill ie about £130 so not cheap compared to ICE home or destination charging costs or even some public charging costs at the right times.
That 66 litres of diesel 2.5 GJ of energy and burning it would produced 177 kgs of CO2 being added to the Earth's atmosphere. Energy per mile would be 1.42 MJ per mile, normal driving and normal car would be around 3 MJ per mile. An EV would typically average about 0.9 MJ per mile so way more efficient than even the most
extreme effort to be efficient. EVs are at least twice as efficient as even the most extreme ICE effort, on average more like 3 to 4 time more efficient. Running costs similarly so.
Just came home 160 miles in torrential rain and was getting 2.8 miles a kWh. I stopped at 80 miles to charge a little as showing only 50 mile range. Charged more than I ment because I only wanted £3 of charge and ended with £12 as busy talking chargers and how bad they are. Left charger and no rain and average speed cameras and 3.2 miles a kWh. 75 miles range left, so money wasted from gabbing on.
Edited by Evolution13
Done that too.
That's one thing that does not happen with liquid fuels, just saying.
Rain saps power in ICE cars similar to EVs it is that EV have far superior data systems we can measure small difference in energy usage. ICE vehicles ars so wasteful of energy, most themselves energy goes out of the exhaust pipe as waste heat, that a mile per gallon list in rain is no big deal. When charging it is easy to monitor the electricity going in to the Joule, program to stop the charge on battery level, which i do alot. Just got to make sure one does not pick up an idle charge.
Worse than downloading more power than one intends, at big expense, is to be charged dosh for being connected but not charging up, that would hurt. Never had that thankfully.
Edited by lol-lol
@lol-lol The Superb they used was a standard one and the only things modded were the fitment of low rolling resistance tyres, which many owners do as well. The only other thing they did was lower the suspension by 15mm to match that of the Greenline version. All Superbs have a smooth underfloor, unless someone has not replaced the various undertrays after doing a service on the car?
The fuel tank holds 66 litres because it is a bigger car than the B and C-segment cars you mentioned; the Superb is D-segment and so has a heavier weight and has a larger wind resistance to overcome. An Octavia is a C-segment car and has a 50-litre tank, but their WLTP ranges are broadly similar, so the extra 16 litres did not give it any advantage in range.
As to the fuel being chilled to allow more fuel to be stored in the tank, as far GWR is concerned, that is not allowed.
What was that about Tesco fuel destroying ICE engines with water and other debris in their fuel, and yet you use it for your 5p and 8p-a-litre discount vouchers, which you use up? 🤨
5 hours ago, lol-lol said:
Rain saps power in ICE cars similar to EVs it is that EV have far superior data systems we can measure small difference in energy usage. ICE vehicles ars so wasteful of energy, most themselves energy goes out of the exhaust pipe as waste heat, that a mile per gallon list in rain is no big deal. Wgen chraging it is easy to monitor the electricity going in to the Joule, program to stop the charge on battery level, which i do alot. Just got to make sure one does not pick up an idle charge.
I think you missed the point of my comment, I was saying that you don't get sidetracked talking to other drivers when doing a splash and dash or even a full refuel with liquid fossil fuel because you have to be there, squeezing the trigger for the fuel to flow to your tank, unlike an EV.
Of course, rain, snow, etc is going to have just as much impact on the rolling resistance of an ICE car as it does on an EV; that's pure physics.
Tescos had contaminated fuel a fuel years back. Silicone contamination. Quite a few people got compensation for engine damage. £8M paid out. Thurrock plant contamination.
If the rate of recharging keeps going up as quick as it has been recently ie 1 MW charging and faster, perhaps we will get a similar trigger mechanism, maybe with a locking trigger like US and Canada, bar Quebec province as state government don't trust their citizens !
I know about that, hence my surprise that you actually admitted to using Tesco fuel after you posted this.
On 03/09/2026 at 15:24, lol-lol said:
Only of fuel pumps giving engine wrecking fuel as Tescos did and I think there gas been other similar instances. DC and AC charges seem to work or not work and I have not heard of battery wrecking over amperage or over voltages thankfully. EVs systems seem good at controlling the amperage and voltages where ICE vehicles will readily accept contaminated fuel, fuel with water in it or the wrong fuel entirely petrol in a diesel car is it not but other way round does not happen due to different nozzle sizes.
Not for many years as have not had an ICE vehicle. When my son went from ICE to EV about a year ago we tended to go to MFG stations and they seem to get the future as they oft seem to have EV chargers and petrol pumps. Do go in to the Tesco fuel station but only to get a meal deal but they always ask if I have got fuel and I can so no each time. Our Tesco is quite a poor one as no EV charging there and Sainsburys seems to be getting the jump on Tescos and I expect Tesco to lose a lot of customers due to their lack of foresight.
Edited by lol-lol
New Dacia Spring, sister product of the new Renault Twingo etech, will go on sale in Spring 2027 reportedly. Same small 27 KWh LFP battery and therefore 150 summer range and 120ish winter range so very much inter town or county rather than cross country.
Price should be sub £15k. Bigger than the 45,65, 100 old model Spring and 80 hp. Apparently the 100 hp, sub 1 tonne Spring was as expensive as a Gilf GTI to insure ! 12 seconds to 60 in the new Spring. Torque presumably lowish line the power. Weight now over 1.2T but it does look much more sturdy.
Fancy a coffee and maybe a few litres of fuel ?
£2.12 a litre, where is that?
It is more than that oop north at some BP, Shell, Esso, Texaco etc. PS. I would rather have a litre of go go juice than a cup of Costa. I do like where charging an EV gets you a free hot drink. But then the electricity is very expensive.
Last week I paid £1.80
There are still places at that price but maybe they have not had to fill their tanks this week.
Here, they shove the price up instantly without filling their tanks
Toddington services near Lutton i gather.
Profiteering !
Price-gouging. Three Monkeys Government / Government Agency. Supposedly the Competitions and Markets Authority found no evidence of that by UK Fuel Retailers. Or 'Widespread Price Gouging in the UK'. Obviously they are incompetent and not fit for purpose. I have never understood why only one Competitions & markets Authority, or as the were called Competitions Commission. They have a monopoly on things.
If you want to know how we are being ripped off by the authorities, watch the YT channel "The Fine Print"
Recently Browsing 1
